('06-'08) P0457 code - charcoal canister questions? - Subaru Forester Owners Forum
post #1 of 12 (permalink) Old 04-22-2019, 05:01 PM Thread Starter
Hi!
2008 Subaru Forester 119,000 automatic. Having P0457 code, not gas cap, thinking that maybe a bad Charcoal Canister Solenoid. From examining the canister, there are some clips on diff. parts, does this mean I can replace the drain vent solenoid or do I have to replace the whole box charcoal canister box?
Thanks so much!
Nozaki is offline
post #2 of 12 (permalink) Old 04-22-2019, 05:42 PM
Feedback Score: 42 reviews
I don't have an answer for you, but perhaps you'll find the answer in one of these threads:
P0457 CEL 2004 Forester - SOLVED!
check engine light code P0457
P0457 Code Solution
P0457: Checking purge and vent solenoids
2.5x_sleeper is offline
post #3 of 12 (permalink) Old 04-23-2019, 03:21 PM Thread Starter
Thank you for the links! I do have to check the filler neck, but what to prepare if it is the Charcoal Canister. One of the links shows someone resolving the issue by replacing his Vapor Canister Vent Valve that he bought on Amazon. It looked like just a separate valve, that I am assuming either removed from the the canister, or is it separate from the "black box" in some Forester years? I guess some years, the valve is built into the Box. Not sure which one I have. If I have to get a whole new one, may need to hit some Junk yards! I will have to get under there again and check the wires to the canister. They looked good, but I will cut back the insulation to check the wires. The former owner had sprayed rubberized undercoating, so the connectors are all covered, but we'll see!
Nozaki is offline
post #4 of 12 (permalink) Old 04-25-2019, 09:14 AM
I'm having the same issue with my '07. The dealership diagnosed that the vent valve was not operating and that the entire canister would need to be replaced. In the previous generation foresters this valve was a separate part, but from 2004 on it is part of the canister.
JacobF is offline
post #5 of 12 (permalink) Old 04-26-2019, 09:17 AM Thread Starter
That was what I was afraid of...see that a whole Charcoal canister online is around $300. Weird that my canister has sections that have metal clips on them, like parts could be removed, though I haven't tried it. I posted couple pics I found Online that look similar to mine. Third pic is perhaps the parts removed from the canister?
ID:	508797   Click image for larger version
ID:	508799   Click image for larger version
Name:	Vapor Canister Vent Valve.jpg
Nozaki is offline
post #6 of 12 (permalink) Old 04-26-2019, 07:08 PM
@Nozaki I pulled the canister on my car today to take a look. I pulled the valve out, which you can see in the attached picture. I think the third picture in your post is from a different generation where the valve and filter box were separate parts.
ID:	508813   Click image for larger version
JacobF is offline
post #7 of 12 (permalink) Old 04-28-2019, 09:51 PM Thread Starter
JacobF thank you for taking the time and going to the effort of pulling your canister. If my canister is bad, would replacing the valve that you pictured removed fix it, or would I have to change the whole thing? On my day off, will really take a good look at the canister and perhaps pull it. Have read that even just small spider webs can cause a blockage in the vent hose. Work as an LNA on an Alzheimer's Unit at a Nursing Home and don't make alot of money. If I have to change the whole thing, wonder how much a junk yard would charge?
Nozaki is offline
post #8 of 12 (permalink) Old 04-29-2019, 07:14 AM
@Nozaki Not sure on your car if replacing just the valve would solve your issue, and I can't find anywhere to buy just the valve. I will probably buy a used complete canister and hope that the valve works in it. It seems like they can be found for under $100. This page has a list of all the vehicles that share the same part: https://parts.subaru.com/p/Subaru_20...2035SA000.html
JacobF is offline
post #9 of 12 (permalink) Old 04-29-2019, 05:01 PM Thread Starter
I did see one on Ebay for around $93 with shipping, may have to go that route. Funny I see Youtube vids of kids removing the canister totally, prob. to get some kind of perceived or real performance boost. Not sure how that would affect passing the emissions test here in NH. Thanks again @JacobF
Nozaki is offline
post #10 of 12 (permalink) Old 05-01-2019, 07:04 AM
One issue I ran into, which you might as well if you are replacing the whole canister, is I could not get the hose off the rear of the canister. It can be seen in pictures 2-4 in this post: https://www.subaruforester.org/vbull...3/#post3785666
I tried using a screw driver to pry the tabs and squeezing with pliers but I could not get it to come loose. Maybe there is someone around here with some trick to removing this fitting.
JacobF is offline
post #11 of 12 (permalink) Old 05-01-2019, 09:59 AM Thread Starter
Damn spiders!
Nozaki is offline
post #12 of 12 (permalink) Old 05-02-2019, 02:24 AM
snaker's Avatar
Transmission: 5spd Manual
I’m having the same issue with the same code & nobody can figure it out. I’m going to try the charcoal canister as well.
2007 Forester Sports XT 5spd
snaker is offline
Similar Threads
('03-'05) how to disconnect the charcoal canister? carmima Problems, Maintenance, and Warranty 2 08-19-2017 05:54 AM
07 forester charcoal canister and solenoid question ldutton6 EJ25 - 2.5L Non-Turbo (1998-2010) 0 07-20-2016 09:56 AM
Evap Leak - Screw through charcoal canister (How to Seal) alextaylor116 EJ25 - 2.5L Non-Turbo (1998-2010) 6 03-22-2016 08:06 PM
('03-'05) Charcoal canister fittment 08 on 04? runerx EJ25 - 2.5L Turbocharged (2004-2013) 0 02-14-2016 01:31 PM
