('06-'08) Engine oil leak - dripping onto the exhaust? - Subaru Forester Owners Forum
post #1 of 9 (permalink) Old 05-11-2019, 03:51 PM Thread Starter
Arcamm's Avatar
Transmission: auto
Unhappy Engine oil leak - dripping onto the exhaust?
My 07 Forester has started leaking oil. It's bad enough that dripping onto the exhaust and burning. The highest point I can see it is around these sensors. Front of the cylinder, drivers side (US). The black area has pooled oil in it. Could it be one of the sensors or the head? I haven't pulled the cam cover off to see if it's a seal.
The oil was over filled and I didn't realize it for a couple of hundred miles. I removed about half a pint.
What could I have broken?
I NEVER ride with people who drive like I do!
Arcamm is offline
post #2 of 9 (permalink) Old 05-11-2019, 04:02 PM
Car Model: 2008 2.5i-2018 XT
Doesn't show me much
adc is offline
post #3 of 9 (permalink) Old 05-11-2019, 04:21 PM
NinoS's Avatar
Car Model: Forester X and XT
Transmission: Manual and Auto
If it's up that high i would think more on the sensor. I had to fix a leak around an AVCS sensor (or actuator? not sure which it is) on my EJ20X - on bottom side of head in this case. In my research i thought i saw that the sensor you point out on the stock engine does often leak - and mine certainly was leaking. In my case it just needed an oring, one bolt to remove it but not sure if that is similar.
NinoS is offline
post #4 of 9 (permalink) Old 05-11-2019, 04:24 PM
Feedback Score: 42 reviews
@Arcamm the engine can be overfill by 1/2 quart to a quart without issues.
Thoroughly clean off the oil residue. Also drop the plastic engine undercover to clean it off & get a better inspection under the engine.
Put everything back together & monitor for oil leaks.
You could leave the engine undercover off while you're looking for the oil leak.
2.5x_sleeper is online now
post #5 of 9 (permalink) Old 05-11-2019, 04:36 PM Thread Starter
Arcamm's Avatar
Transmission: auto
I just got in from my shop. I dropped the cover and there's lots of oil down there. I'll clean it up tomorrow and try to get a better picture of where it's coming from.
Arcamm is offline
post #6 of 9 (permalink) Old 05-12-2019, 10:26 AM Thread Starter
Arcamm's Avatar
Transmission: auto
Spent some time in the shop. Cleaned up as much as I could. No apparent leak source. It looks like it starts up around the sensors. There was oil on the bottom of the cam cover, but I pulled the cover and it's dry inside. I ran it for a few minutes and will go look again after it's cooled off a bit.
Arcamm is offline
post #7 of 9 (permalink) Old 05-12-2019, 02:12 PM
If that sensor is below your alternator, it is probably your oil pressure switch. I had to replace mine on my 2000 because it was leaking. It is a $25 part at the dealer.
ryaninpdx is online now
post #8 of 9 (permalink) Old 05-12-2019, 03:39 PM Thread Starter
Arcamm's Avatar
Transmission: auto
I cleaned up the bottom of the cylinder/head and dried it off. I did the area around the sensors too. I'll let it sit over night and see what the bottom looks like tomorrow morning.
The one I "think" might be leaking is the red arrow. It's the highest point with oil. Not sure about the one with the white arrow. I don't even know what they are.
Arcamm is offline
post #9 of 9 (permalink) Old 05-21-2019, 08:04 AM Thread Starter
Arcamm's Avatar
Transmission: auto
I got one shop to look it over, leaky head gaskets, leaky power steering pump, leaky water pump, and a leaky "VALVE-AY-OIL". Just over 4gs to fix including timing belt.
Arcamm is offline
Similar Threads
('09-'13) Engine oil leak from Head Gasket diagnosis from Subaru dealer napalicoast8 Problems, Maintenance, and Warranty 0 12-17-2017 01:43 PM
('09-'13) Oil pan/seperator plate leak mlhoward EJ25 - 2.5L Non-Turbo (1998-2010) 0 11-02-2016 01:34 PM
('03-'05) supposedly have an engine oil leak and rear differential leak on my 03 X Subguy58 Problems, Maintenance, and Warranty 8 02-09-2016 02:02 PM
('06-'08) Oil filter leak and white smoke tedandhogan EJ25 - 2.5L Turbocharged (2004-2013) 7 01-19-2016 10:03 AM
('03-'05) Oil Leak Under Engine - Contains Pics - Please Help rg-one Problems, Maintenance, and Warranty 22 02-14-2011 05:12 AM
