('98-'00) Cooling fans - engine fans won't turn on (merged thread) - Subaru Forester Owners Forum
 3Likes
post #1 of 60 (permalink) Old 04-30-2019, 08:19 AM Thread Starter
Car Model: Forester S
My son's Forester has a fan problem. They don't come on. I did the diagnostic test and the fans function. That means the fuses and relays are working properly. I replaced the temperature sensor, not a fun job, but still they won't work upon warm up, or when the A/C is turned on. Any ideas where to look next? Help.
Derek'sForester is offline
post #2 of 60 (permalink) Old 04-30-2019, 08:24 AM
Feedback Score: 42 reviews
@Derek'sForester I see this is your first forum post, so welcome to the forum from Oregon!
Also...
For the best forum experience, we recommend completing your "Public Profile". Specifically, the "About Me" section (Edit Your Details). This displays every time you make a post on the forum. This will provide information members may need to reply to your forum posts. You can edit this field via the "User Control Panel", aka, "User CP.
If you're using a mobile device, you may need to use a laptop or desktop computer to see all the user tools.
2.5x_sleeper is online now
post #3 of 60 (permalink) Old 05-04-2019, 02:03 PM Thread Starter
engine fans won't turn on in normal conditions.
I keep trying to post questions here, but only one has ever showed up. I still need someone to try to tell me if there are two temperature sensors for the electrical radiator fan unit and where they are. I have replaced the coolant temperature sensor under the intake manifold. I have also used the green wires under the dash to show if the fans work. They do, but not when the A/C is on or when the engine gets hot. Is the ECU the only thing left?
post #4 of 60 (permalink) Old 05-04-2019, 02:20 PM
karlaudi's Avatar
Transmission: 5-speed manual
Did you check the radiator thermofan switch(es)? on the radiator?
karlaudi is offline
post #5 of 60 (permalink) Old 05-04-2019, 02:50 PM Thread Starter
Where? I've never heard of them. I'll go out and look. The only wires I see going to the fans are the power wires.
post #6 of 60 (permalink) Old 05-04-2019, 04:00 PM
karlaudi's Avatar
Thermofan switches are most often located in the bottom tank of the radiator close to the lower hose. Or the lower radiator hose on side tank radiators. They are what turns electric radiator cooling fans on according to coolant temperature in the radiator. Check your thermostat too if no hot coolant reaches the radiator so that the fans turn on.
You may wish to see if a Subaru Service Manual is available from Subaru for your model and year. The price is right for downloading a PDF manual plus other information.
The link:
https://techinfo.subaru.com/stis/#/login
karlaudi is offline
post #7 of 60 (permalink) Old 05-04-2019, 04:34 PM
Originally Posted by Derek'sForester View Post
I keep trying to post questions here, but only one has ever showed up. <snipped>
No need to create a new thread when you already have an active thread on the same subject. Per the forum posting rules, your threads have been merged.
Again...
post #8 of 60 (permalink) Old 05-04-2019, 05:12 PM Thread Starter
I am new to your forum and I am sorry if I didn't know some of your rules. I just wanted to find some information. I am not new to Subarus. I've owned two SVXs as well as having done several timing belt replacements on this particular engine. I'll try to follow your rules from now on, if I have broken them. I just wanted some help.
post #9 of 60 (permalink) Old 05-04-2019, 05:21 PM
@Derek'sForester did you read this on my previous posts?
post #10 of 60 (permalink) Old 05-04-2019, 06:27 PM Thread Starter
I have done what you wanted Bobby. Any more issues you have with a fellow Oregonian?
post #11 of 60 (permalink) Old 05-04-2019, 06:49 PM
No, no issues. I'm just trying to help you get the help you're looking for.
post #12 of 60 (permalink) Old 05-05-2019, 09:21 AM
@Derek'sForester if connecting the test connector verifies the main & sub fan are working, then that appears to be pointing to a ECM or sensor issue. Note that the fans are controlled by the ECM & not directly by the test connector or sensors.
Also...
Is this fan issue a new problem that just started up?
'99-'02 Forester
post #13 of 60 (permalink) Old 05-05-2019, 09:41 AM Thread Starter
It was intermittent for about a week, now it's all the time. We haven't driven the car in more than a week at this point.
I replaced the temperature sensor at the rear of the engine last Sunday. No change.
Thanks for the wiring diagram it helps. I ordered a Haynes manual and should receive it tomorrow. I'm putting it up on ramps today and I'll try to locate the sensors that were referred to in an earlier post. If it's the ECM then I guess the car is toast at 215,000 miles.
post #14 of 60 (permalink) Old 05-05-2019, 09:51 AM
Kevin's Avatar
Car Year: MY03
In the past on my MY'03 the connectors for the fans have become corroded so perhaps worth investigating if you have similar connectors.
MY'97 Outback RIP
Kevin is online now
post #15 of 60 (permalink) Old 05-05-2019, 10:00 AM Thread Starter
Thanks for the information. I'll clean them up when I'm under the car, but it was my impression that if the fans start doing the diagnostic it wouldn't be a connection problem. I've had Subarus before, but never had an issue like this. Of course I've had SVXs and worked on Outbacks, but Foresters are pretty new to me.
Similar Threads
Why is this green plug not connected? (merged thread) agentorange Interior and Electronics 68 11-30-2018 04:57 PM
('03-'05) Replace EJ25 Head Gasket - Without Removing Engine or Intake Manifold craddojc1717 EJ25 - 2.5L Non-Turbo (1998-2010) 7 10-25-2016 11:23 AM
('14-'18) '16 Owner's Manual Update from SOA re: Engine Oil Consumption stiers11 FB25 - 2.5L Non-Turbo (2011- 2018) 9 01-16-2016 03:26 PM
Oil FAQ GIT-R-DONE Problems, Maintenance, and Warranty 35 07-15-2010 12:17 PM
Bought 2003, Engine makes ticking noise on startup. Is this normal? abbyw Problems, Maintenance, and Warranty 1 03-04-2006 12:14 PM
