('14-'18) Stuck with my Hella wiring - Subaru Forester Owners Forum
 3Likes
  • 1 Post By 2.5x_sleeper
  • 2 Post By DragonSubie7
post #1 of 7 (permalink) Old 05-09-2019, 12:35 PM Thread Starter
8lackie's Avatar
Transmission: automatic
I was trying to follow this tutorial, but am stuck. Hella horn install with relay and fuse.
I've gotten to the point where I can unconnect the old horn. Then I'm not clear what happens. I have a relay harness, I know where everything goes .....well except two things. 1. the new horn connections.....that activate the horn button and where exactly do those get connected.
2. On the positive battery terminal, does it matter which one of the connection I use?
Thank you for any help
Name:	Hell horn Forester XT.jpg
ID:	509539   Click image for larger version
Name:	Hell horn forester xt 02.jpg
8lackie
8lackie is offline
post #2 of 7 (permalink) Old 05-09-2019, 01:13 PM
Feedback Score: 42 reviews
@8lackie use @Poseidon wiring diagram. It shows everything you need to know.
As to where to connect at the +12V battery terminal. I would connect at the bolt near the clamp.
2.5x_sleeper is online now
post #3 of 7 (permalink) Old 05-09-2019, 03:02 PM Thread Starter
8lackie's Avatar
Thanks Bobby,
That is the one I was following. I get stuck at where the connectors go for the horn button. It's not clear where the "stock wires to horn" are. Or do I cut the wires and splice them into the thingy in my first photo -which I might add looks like it terminates....I've not been able to separate it from itself, if that makes any sense?
Addendum: It may be that Poisidon explains iit in this 3rd paragraph under his diagram, but I still don't understand it.
"I connected the wire from the center stock horn to #86 . Relay post #86 was the part that was unclear to me. I kept trying to figure out how to splice directly into the wires from the horn button. I finally figured out that I just needed to use the stock horn wire from the horn itself. When that wire is activated by the horn button, it activates the aftermarket relay and horns."
8lackie
8lackie is offline
post #4 of 7 (permalink) Old 05-09-2019, 04:14 PM
@8lackie looking on the factory wiring diagram, you have 2 factory horns. The trigger is +12V, so you'd wire one side of the relay coil you're installing to ground & connect one of wires from the factory horn to the other relay coil. That completes the relay circuit, so when the horn button is pressed, the relay will operate.
8lackie likes this.
post #5 of 7 (permalink) Old 05-09-2019, 04:23 PM Thread Starter
8lackie's Avatar
I figured it out. It was where to plug in the horn button relay. I just cant seem to pull the thing apart to plug in to it. I suppose I could just clip it and then connect them that way.
About 3:15 on this video
https://www.subispeed.com/2015-subar...i#.XNRnbth7mCg
8lackie
8lackie is offline
post #6 of 7 (permalink) Old 05-10-2019, 06:06 AM
@8lackie -
When you run your positive wire from the battery terminal, make sure you have a fuse on it!
An inline fuse with a spade connector works well, and ideally you place it near the battery connection.
I picked up one wired in with a terminal lug already connected.
Since you need to route a wire around some sheet metal edges to power the horn, the fuse will blow if you get a short, rather than your wire melting or starting a fire.
It will also allow you to pull the fuse to stop the horn from sounding if the relay sticks on.
2.5x_sleeper and 8lackie like this.
DragonSubie7 is offline
post #7 of 7 (permalink) Old 05-20-2019, 11:35 AM Thread Starter
8lackie's Avatar
Can you hear me now?
I bought a harness from Amazon.
iJDMTOY (1) 12V Horn Wiring Harness Relay Kit For Car Truck Grille Mount Blast Tone Horns (Actual Horn Not Included)
which has a fuse built in (near the battery connection, as you recommended) What was throwing me was the connector for the horn, which looked like, what I now know to be a bullet connector and I needed to connect it to a female spade. I had to jerryrig a male connector to the bullet connector so I could plug in to the horn circuit.
I hooked up some HELLA 012010801 Blue Trumpet Horn Kit, 12 V, 400/500 Hz (Universal Fit). They're loud like a boss.
Name:	bullet connectors.jpeg
ID:	510245   Click image for larger version
8lackie
8lackie is offline
Similar Threads
('19+) My 2019 Subaru Forester Sport - Let the modz begin! Sdcerreta Members' Journals 217 06-16-2019 07:35 PM
('14-'18) How to install Rally Innovations light bar and LED offroad light GeoJosh Lighting and Electrical 44 07-06-2018 03:34 AM
('03-'05) OEM horn wiring help - trying to install Hella horns mtlmsl Lighting and Electrical 9 08-30-2017 08:48 AM
('03-'05) Hella Prodrive wiring mgb2 Lighting and Electrical 0 06-03-2015 06:44 PM
Hella Super Horn Wiring toysbyus Lighting and Electrical 5 04-29-2006 08:25 AM
