('06-'08) More LED issues - Maybe? - Updated! - Subaru Forester Owners Forum
 1Likes
  • 1 Post By 2.5x_sleeper
post #1 of 11 (permalink) Old 05-21-2019, 03:59 PM Thread Starter
Arcamm's Avatar
Transmission: auto
I changed out a lot of my incandescent bulbs with LEDs awhile ago. I had some issues with the exterior lights staying on (dimly) and causing excessive battery drain. I cured it by mixing LED and incan bulbs.
It wasn't a good solution so I removed all of the cheap led bulbs and replaced them with Diode Dynamic LEDs.
Now I have this problem. If I don't turn off my headlights before I shut down the engine, the rear lights will stay on, but will be dim. If I turn off the headlight switch before I shut off the ignition, they will go off. If they are on, the only way to get them off is turn the ignition back on, turn off the headlight switch, then shut the ignition off. If I just turn the headlight switch off, they will stay on. This will drain the battery down if I don't run it for a couple of days.
Any ideas of what might be wrong? Has anybody ese had an issue like this?
I NEVER ride with people who drive like I do!
Arcamm is online now
post #2 of 11 (permalink) Old 05-21-2019, 05:12 PM
Feedback Score: 42 reviews
@Arcamm have you run this past @Diode Dynamics to see if they have a fix for this?
This thread came to my mind: LED taillights staying on - SOLVED! I don't think you'll like the solution & you replied to that thread!
Arcamm likes this.
2.5x_sleeper is online now
post #3 of 11 (permalink) Old 05-21-2019, 05:39 PM Thread Starter
Arcamm's Avatar
Transmission: auto
Thanks Bobby, I remember that thread. I had hoped switching out to high quality LEDs would solve the issue. Looks like that's a no. I'll call @Diode Dynamics and see what they say. Sounds like I won't be the first to ask the question. I had looked at their webpage, but they don't have any "tech Support" areas.
Good thing I didn't throw away my incandescent bulbs.
post #4 of 11 (permalink) Old 05-21-2019, 05:49 PM
Car Year: 2018
Weird. In my 2007 XS I switched all external lights to LED except for turn signals, headlamps, and fogs, and everything worked properly. I used Philips bulbs.
Botnik is offline
post #5 of 11 (permalink) Old 05-21-2019, 05:58 PM
@Arcamm with the mentions on this thread & @Diode Dynamics being a forum supporting vendor, hopefully they'll post a reply here!
post #6 of 11 (permalink) Old 05-21-2019, 06:31 PM Thread Starter
Arcamm's Avatar
Transmission: auto
I'm going to start doing some swapping to see if I can get it to stop. I'll start with the back turn signals.
post #7 of 11 (permalink) Old 05-23-2019, 02:47 PM Thread Starter
Arcamm's Avatar
Transmission: auto
Some progress. Maybe.
I ordered some incandescent turn signal bulbs to eliminate them as a culprit. I removed the rear turn signal housing and guess what? These is already an incan bulb in there. Plan A bites the dust!
So plan B is to remove the last two "Amazon guarantied canbus compatible" LED bulbs, over the license plate. So I turn on the car, turn on the light switch then turn off the car. As usual, the back lights still glow. Except for the two "Amazon guarantied canbus compatible" LED bulbs. So I remove one of the LEDs and replace it with an incandescent bulb. The incan bulb glows! I remove the second LED and put in the incan bulb, but it doesn't glow. I look at the first one and it's off! I look at the tail lights and they are off. It was still daylight when I did this so I'll celebrate as soon as the sun goes down.
Now I wonder if I replace the incan bulbs with Diode Dynamic bulbs, will they come back on or not? Guess I'll wait until their next sale and see.
post #8 of 11 (permalink) Old 05-23-2019, 04:59 PM
@Arcamm any feedback from @Diode Dynamics
post #9 of 11 (permalink) Old 05-23-2019, 05:19 PM Thread Starter
Arcamm's Avatar
Transmission: auto
@2.5x_sleeper No and I have held off calling them until I had all of the "other" LEDs out of the system. All that I have now is incandescent bulbs and Diode Dynamic LEDs. It appears the issue might be resolved.
Now I will start adding more LEDs and see if it starts back up again. I'll add the two for the license, but I don't want to spend $9 to ship $8 worth of LEDs. I'm cheap. I'll wait for the next time they have a sale.
My budget kind of got busted by the head gasket leak repair.
post #10 of 11 (permalink) Old 05-23-2019, 06:14 PM
Car Year: 2018
It'd be interesting to look at the schematic of the Philips and DD products and compare them with schematics for whatever else you had in there, to see what was causing the problem.
Botnik is offline
post #11 of 11 (permalink) Old 05-23-2019, 06:37 PM Thread Starter
Arcamm's Avatar
Transmission: auto
I'd like to see the schematics too. I'm still looking for a good explanation on canbus or what ever Subaru uses in their lighting systems.
Similar Threads
('14-'18) MY17 - Full Guide to Installing new Boot LED upgrade kit kickling Lighting and Electrical 16 02-19-2019 01:35 PM
[14+ Forester SJ] COLIN SHREAD FULL LED TAILLIGHTS VarcoRep Supporting Vendors 433 12-12-2018 06:07 AM
('14-'18) How to install Rally Innovations light bar and LED offroad light GeoJosh Lighting and Electrical 44 07-06-2018 03:34 AM
[14+ Forester SJ] Varco LED Projector Fog w/ DRL (Dual Function) VarcoRep Supporting Vendors 12 11-21-2016 12:47 AM
(All Years) Wrong turn in LED lumen search Green Darter Lighting and Electrical 3 03-10-2015 02:39 AM
