('19+) Headlights won't turn off - Merged thread - Subaru Forester Owners Forum
 2Likes
post #1 of 21 (permalink) Old 05-10-2019, 11:03 AM Thread Starter
I have a 2019 Premium Forester which I received two days ago. I am having the following problem.
After shifting to reverse or drive the low beam headlights come on. There is no way to turn them off until the engine is stopped. It does not matter what the setting is: AUTO or any other setting.
I took this to the dealer. To make a long story short the service manager and the salesman eventually agreed. They had no answer.
Any thoughts on what might be causing this.
garyquicker is offline
post #2 of 21 (permalink) Old 05-10-2019, 11:53 AM
Car Year: 2018
Car Model: 2.5i Premium
DRLs?
bbottomley is online now
post #3 of 21 (permalink) Old 05-10-2019, 12:01 PM
Car Year: 2019
To build off of what @bbottomley said, in anything other than the Limited and Touring, the main headlight also serves as the DRL. In the Limited and Touring they use the "C Light" or "boomerang" for DRL. This is discussed in this thread.
jmw15 likes this.
ryanb is offline
post #4 of 21 (permalink) Old 05-10-2019, 12:27 PM
jmw15's Avatar
Car Year: 2019
Car Model: Touring
An easy way to verify that indeed the lights are just DRL, look at the tail lights, not on when headlights are off.
2019 Touring -Red
2019 Touring - Green
jmw15 is offline
post #5 of 21 (permalink) Old 05-10-2019, 01:47 PM
Car Year: 2018
The DRLs on my 2018 shut off when the transmission is in Park. Otherwise they are always on.
ForesterBill is offline
post #6 of 21 (permalink) Old 05-10-2019, 02:02 PM
Car Year: 2018
Everything sounds like DRLs, but for the unknowing reaction from the service manager.
Subaru's procedure has always been that DRLs come on when the engine is running, parking brake is off, and (if automatic transmission) is not in Park. They have swapped around a bit between using low beams or high beams, always running at less than full brilliance, and in recent years have switched to fancy LEDs in some of the higher priced models—not yours or mine.
post #7 of 21 (permalink) Old 05-10-2019, 05:09 PM
I bet the manual goes over it.
OriginalTwoTone is offline
post #8 of 21 (permalink) Old 05-10-2019, 05:11 PM Thread Starter
Head lights won't turn off 2
I posted the following post previously:
I received answers such as DSL.
Common sense tells me those LOW BEAM HEADLIGHTS should not come on when shifting to reverse or drive. Why have the sensor that turns your headlights on at dusk if they are already on.
post #9 of 21 (permalink) Old 05-10-2019, 05:43 PM
Read both of your posts. If I understand your question,
I agree with the folks who suggested it’s the DRL’s. They are always on when car is not in park.
To check, have someone put car in gear and look at your headlamps. If the bulbs on the inner part of the headlamp are on, these are the DRLs. The actual headlights are the outer bulbs.
The headlights are brighter than the DRLs. When you turn on the headlights, the DRLs go off.
Steel City Subi is offline
post #10 of 21 (permalink) Old 05-10-2019, 05:47 PM
Car Year: 2018
I have merged your new thread with the original one to keep things together.
DRLs (Daytime Running Lights) are to help other cars see you in daytime. On most Subarus they aren't a separate set of lights but a special usage of the headlights. They light up one set of headlights at less than full brilliance. Just the headlights. No taillights or anything else.
'Turning on' the headlights lights them up at full brilliance, enables use of both high and low beams, and also lights up tail lights and a few others. For nighttime driving or periods of low visibility.
post #11 of 21 (permalink) Old 05-11-2019, 05:26 AM
Careful throwing out the common sense bit. Sounds like you haven't owned a modern vehicle. Common Sense would be to take the time to read the owners manual.
post #12 of 21 (permalink) Old 05-11-2019, 02:24 PM
FelineFreddie's Avatar
Car Year: 2019
Car Model: Forester Touring
How about the simple approach?
Go to the dealership and see what happens with the other models the dealership has on its lot like the one you own...
I’m betting on the DRL answer.
FelineFreddie is offline
post #13 of 21 (permalink) Old 05-13-2019, 09:04 AM Thread Starter
Headlights won't turn off # 3
I previously posted the following message:
I received answers such as DRL.
Another suggestion was to turn the lights on when in park and then compare them to the lights that are on when in drive. I did that. There is no difference. The outside LED and the inside yellow lights are both on. I said above that the service manager and the salesman did not have an answer. That was a long story short. I will expand that story more. For the first several minutes they thought I simply did not understand how the lights worked. The service manager told me they were on because we were inside and it was somewhat dark. I said that didn't matter and let's take it outside. We took it outside and the low beam headlights still came on. The service manager got inside the car and fooled around with stuff. I don't know what. The service manager then agreed with me. He had no answer and said he would try to find out something. He has not called.
Bottom line: they come on when shifted into reverse or drive; they will not turn off until the car is shifted into park.
I think there is a defect with something. It is going to be a warranty issue and I am not looking forward to it. I think it will be a battle. Hopefully not.
post #14 of 21 (permalink) Old 05-13-2019, 09:20 AM
Car Year: 2018
Once again I have merged your threads. Please do not start new threads to continue an already established discussion. We have a strong policy here of keeping everything together for future reference.
post #15 of 21 (permalink) Old 05-13-2019, 09:57 AM Thread Starter
Nonsense. I am 68 years old. I have owned plenty of modern cars. I have looked in the manual, a lot. No answer. That manual is by far the worst manual I have ever had.
Similar Threads
Roof Rack Pictures (merged thread) Nachas Member Galleries 814 07-07-2019 08:14 PM
(All Years) Replacing Instrument/Dash Lights? Help (merged thread) cojobi Interior and Electronics 188 03-14-2019 09:33 AM
How to turn better than an STI for cheap! wadejg Suspension and Handling 490 02-13-2019 12:49 AM
subaruforester.org - unique hand wave (merged thread) SubieOutlaw General Forum 113 09-03-2018 10:34 AM
Hidden features??? (merged thread) 18tgls General Forum 303 07-20-2017 02:56 AM
