('19+) Rear power lift gate won't open (merged thread) - SOLVED! - Subaru Forester Owners Forum
 76Likes
post #1 of 178 (permalink) Old 11-21-2018, 01:51 PM Thread Starter
Car Year: 2019
Car Model: Forester Touring
New 2019 Touring. The rear liftgate all of a sudden won't open, no matter whether I'm long-pressing the button on the key fob, the power liftgate button at the lower left of the steering wheel, or the physical button on the actual liftgate itself. It worked fine up until today, now nothing. Whichever method I use it gives me 3 beeps to show there's some kind of error. I've locked and unlocked the car numerous times. I've driven the car and locked and unlocked it in several locations. When I try to open the rear gate by any method, I always get those three beeps and it never opens. Any advice?
Update - Resolved!
It turns out I had to take it to the dealer to have it "reset". I asked if that would be something I could do myself if this ever happened again. The answer was no, bring it to them.
The service technician said the cause of this was likely trying to close the automatic liftgate *manually* using too much force.
Sent from my SM-N960U using Tapatalk
To those who are experiencing this problem, make sure you read this post in this thread by @forester022519
The power lift gate problem should not be an issue requiring an emergency visit to the dealer if you're armed with his great advice. Print out his post and keep a copy in the glove compartment!
Jelks is offline
post #2 of 178 (permalink) Old 12-02-2018, 10:05 AM
Car Year: 19
Car Model: Forester Sport
My power lift gate wont open either. only had my 2019 Sport for 1 week. Really don't have time to take it to a dealer. I wonder what they do for a "reset"?
diypunx is offline
post #3 of 178 (permalink) Old 12-02-2018, 11:23 AM
New User
SAME problem. SOOO FRUSTRATING! Just had our brand new 2019 back to the shop because of a brake issue on Friday and then this!!! We are approx 45 miles from a dealership! Thank goodness for the internet! We found a post that said to disconnect battery and wait a minute to reconnect it to allow a reset. IT WORKED!!!
diypunx and Jelks like this.
gigi2twins is offline
post #4 of 178 (permalink) Old 12-02-2018, 12:05 PM
Car Year: 19
@gigi2twins Thanks for the info. Not looking forward to having to reboot this thing like it's a Windows 95 computer just to be able to open the lift gate...Haha
Sent from my SM-G960U using Tapatalk
subatron likes this.
diypunx is offline
post #5 of 178 (permalink) Old 12-04-2018, 09:41 AM
Car Year: 19
2019 Power lift gate is now working again as it should. I disconnected the negative battery cable and turned on the headlights to drain any remaining juice in the system and waited 2 minutes.
8lackie, securityguy and Jelks like this.
diypunx is offline
post #6 of 178 (permalink) Old 12-22-2018, 12:18 PM
Car Year: 2019
I had the same issue today. The rear lift gate wouldnt open with the 3 beeps. Disconnected the negative cable from the battery and waited about a minute. Hooked it back up and i could hear the motors on the gate cycle. Thx forum dudes, it now works. Hopefully there is a software fix they can come up with to cycle the motors if they end up in a stuck position.
iamdunker is offline
post #7 of 178 (permalink) Old 12-22-2018, 01:24 PM
Car Year: 19
@iamdunker Call Subaru and report the problem. Hopefully they will come up with a permanent fix if enough people report the issue.
diypunx is offline
post #8 of 178 (permalink) Old 12-22-2018, 02:42 PM
Car Year: 2019
Also have a 2019 Subaru Touring and the same happened to me. My solution - I pressed the button on the lift gate and held it for a few seconds; let go and waited a couple of seconds and then pressed the button again and the gate opened. Didn't have to take to the dealer - and I don't think this is or should be necessary.
Dan
Banjo Man is offline
post #9 of 178 (permalink) Old 12-23-2018, 09:08 AM
another interesting discovery...on a 2019 Forester. Drive into the garage....wife (driving) opens her door and pushes the open tailgate button on her door....tailgate starts to go up. I (passenger) then open my door to get out.....tailgate stops going up!!!!!! I am hard pressed to think of a situation where this is a good or "safer" design.....
Solution....get back in car...close all doors, push button on door to close the hatch...then after it's closed, push it and sit in the car with the doors closed while the hatch opens.
ghstudio is offline
post #10 of 178 (permalink) Old 01-06-2019, 11:28 AM
Have this same issue happen to me yesterday on my 19 touring. I followed your solution and it works. Thank you for saving me a trip to the dealer or disconnecting the battery.
Seems like this is a common problem for the auto lift gates. I hope Subaru can have a perma fix for this. unless this is the nature of using auto lift, then I wish there is an alternative way to open it mechanically like a garage door.
Subbier is offline
post #11 of 178 (permalink) Old 01-08-2019, 10:20 AM
I tried holding the rear hatch button and this is what happened. I pressed and held the rear button. It gave me the three beeps. I continued to hold the button through the beeps without releasing it. After about 5 or 6 seconds (just hold it until this happens however long that may be), the car gave me to the two unlocking beeps and lights flashed. The hatch proceeded to raise about a quarter of the way and then close again and gave a flash/beep confirmation. it worked normally after that. So basically, just press and hold until it did its own reset is what it seemed like.
Jongett36 is offline
post #12 of 178 (permalink) Old 01-10-2019, 11:49 AM
Car Year: 2019
Car Model: Limited
I ran into the same issue, and fixed it the same way: hold in the button on the liftgate itself for at least 7-8 seconds. The gate will eventually pop open, and you can lift it yourself.
If the problem returns, I would strongly encourage you to take it back to the dealer and request a warranty repair. Even though this rates "mildly annoying" for most of us, and even though there might not be an immediate fix, it will help all of us to start a paper trail with Subaru.
19Limited is offline
post #13 of 178 (permalink) Old 01-12-2019, 05:40 PM
Same issue here. I was super pissed because I had just left costco with a bunch of groceries and a crying baby when stupid tailgate wouldnt open. Car is less than 2 weeks old. Unacceptable. Didnt know what to do at the moment. I really hope I didnt pay all that money for a car with a rear lift gate issue.
Im trying the battery fix now and will try holding the button down next time it happens - hope to god it doesnt happen again.
Nannattack is offline
post #14 of 178 (permalink) Old 01-19-2019, 11:52 AM
1carguy's Avatar
Car Year: 2019
Transmission: auto
Angry
2019 Forester - I can't get the rear tailgate to open. I get the normal two beeps then 3 more quick ones.
No motors running, nothing happens except the beeping. I've tried locking and unlocking all the doors, starting & stopping the engine. The unlock on the doors works OK. Dealer can't look at the car until Monday. Wish there was a manual unlock function.
I've got things that I need to get out of the car, and they won't fit thru the side doors.
Any ideas? Thanks
1carguy is offline
post #15 of 178 (permalink) Old 01-19-2019, 03:22 PM
treeman's Avatar
Have you tried pushing the button manually or just the key fob? My 2017 Touring has issues like that on occasion when I use the key fob system rather than the manual.
treeman is offline
