Inconvenience Outlets - Page 2 - Subaru Forester Owners Forum
post #16 of 42 (permalink) Old 12-22-2006, 08:42 PM
Mudhoney's Avatar
Car Year: 13
mission successful
Hello, I successfully completed this mod today on my Aus MY06 Forester. The wiring plug is red on mine, and pins 3 & 4 are the right ones to join. Some pictures FYI (sorry about the blurry pics). You can see the relays on the right of the fuse block in the first picture. There were two round relays on the right of the block, but I have temporarily removed the lower relay in this picture and you can see the red plug behind it.
As you look at the red block with the tab at the top, the lugs to connect are the top right and bottom right, as indicated on the side of the relay (pins 3 and 4) if you pull it out.
Note that I also spotted a green plug and socket under there (fifth picture) which I thought I had accidentally knocked apart, however plugging them together caused the engine indicator light to flash, so I unplugged that. Anyone know what it is? Something to do with emission control?
Cheers,
Mud
ID:	4055   Click image for larger version
ID:	4056   Click image for larger version
ID:	4057   Click image for larger version
ID:	4058   Click image for larger version
Mudhoney is offline
post #17 of 42 (permalink) Old 12-22-2006, 08:53 PM
Hondaslayer's Avatar
Car Model: Forester "S" lifted.
Transmission: Bog-o-matic
Those green connectors are the check mode connectors.
You would only need to plug them in for re-flashing.
It's real velour. Just let yourself go!
Hondaslayer is offline
post #18 of 42 (permalink) Old 12-22-2006, 09:22 PM
Mudhoney's Avatar
Car Year: 13
re-flashing as in engine management firmware?
Mudhoney is offline
post #19 of 42 (permalink) Old 12-31-2006, 03:05 AM
Mudhoney's Avatar
Car Year: 13
footnote: the accessory outlets are on the same fuse as the power mirrors (at least on my MY06 XS). Test the power mirrors after the mod to check you haven't popped the fuse (as I did).
btw, why does this thread keep disappearing??
Mudhoney is offline
post #20 of 42 (permalink) Old 12-31-2006, 03:23 AM
Kevin's Avatar
Car Year: MY03
Maybe you need to edit User CP / Options / Default thread cut off
MY'97 Outback RIP
Kevin is offline
post #21 of 42 (permalink) Old 01-09-2007, 11:03 AM
agkq62's Avatar
Car Model: XTEn
Just feeling my way into this mod. Mine has three relays that are held to the side of the fuse box with a plastic fittings, not a lot of room to get your hand in. Do these pull off from the fuse box or how do you free the relays.
Thanks Max.
2005 UK XTEn 4EAT sports shift
agkq62 is offline
post #22 of 42 (permalink) Old 02-27-2007, 05:54 PM
Mudhoney's Avatar
Car Year: 13
The little white plastic rings holding them in have a releaseable clip. Just don't use too much force or it may snap.
Mudhoney is offline
post #23 of 42 (permalink) Old 03-20-2007, 03:41 PM
Mudhoney's Avatar
Car Year: 13
further to this; I obtained a little device to prevent excessive battery discharge similar to the ones mentioned above. It cost me AU$33 from Battery World in Collingwood, Melbourne, Australia.
Mudhoney is offline
post #24 of 42 (permalink) Old 03-21-2007, 02:01 PM
Emeritus Forum Staff
BAC5.2's Avatar
Car Model: Outback XT-B
Just wire the power of the socket to a 12v constant signal. Use the wire heading to the clock or something.
It never really bothered me enough to change it.
BAC5.2 is offline
post #25 of 42 (permalink) Old 10-05-2007, 07:12 PM
Car Model: 2.5 X Prem
I have a MY07 and found six black rectangle relays on the right and two more on the left of the fuse block. They seem to be clipped in with ears on both sides and I haven't yet gotten one out to test which of these would be the rear accessory relay. Has anyone figured out which is right the right one in this MY? Any advice for getting one out of its socket?
maifeld is offline
post #26 of 42 (permalink) Old 10-12-2008, 07:12 PM
Anyone try this on a 2008 Forester? Looks different. Info appreciated.
Rich
Gun Barrel City TX
gbctx is offline
post #27 of 42 (permalink) Old 10-17-2008, 02:35 PM
Kevin's Avatar
Car Year: MY03
For camping & short stay purposes, I have another way to keep power at the outlets. I had a plain metal key cut and use it to turn on the accessories. It won't start the car of course; and the car can be locked.
The original reason I got this key cut was to keep in my shorts when swimming and hide the ignition key inside the car.
MY'97 Outback RIP
Kevin is offline
post #28 of 42 (permalink) Old 08-02-2009, 10:59 AM
Hello,
Has anyone done this to the 2009 Forester? If so, which relay and pins do you jump?
TexGX
TexGX
2009 Forester
2004 GX470
TexGX is offline
post #29 of 42 (permalink) Old 08-14-2009, 08:56 AM
ajsmama's Avatar
Originally Posted by TexGX View Post
Hello,
TexGX
I'm with you...I have an 2010 Forester 2.5X Premium and I think it is very annoying not to have a "hot" accesory outlet! Not sure how to do it on the 2010 though. Mine does not look like the others pics. Any ideas out there?
ajsmama
2010 Forester 2.5X premium Auto Trans
ajsmama is offline
post #30 of 42 (permalink) Old 08-14-2009, 09:40 AM
spiritX's Avatar
again, protecting the battery is more important than the convenience. i wouldn't do this without the auto cut-off device.
spiritX is offline
