Inconvenience Outlets - Subaru Forester Owners Forum
post #1 of 42 (permalink) Old 02-01-2006, 05:18 AM
jkd
Guest
Posts: n/a
Unhappy Inconvenience Outlets
One thing I really dislike about my shiny new 06 FXT MT is the fact that the cigarette lighter outlet is tied to the ignition key. Turn the car off, the outlets are off. Or, when you're getting to a Shiny New Clutch, stall the engine, and the outlets get vampired to death by the starter motor. In the front of the car, these power interruptions make my Garmin Streetpilot 2720 go through a power cycle/reboot. I haven't tried it yet, but I suspect that I'm not going to be able to use my 12 volt "flashlight" unless the key is switched on.
Has anyone tried rerouting the feeds for these outlets to bypass the ignition key requirement?
post #2 of 42 (permalink) Old 02-01-2006, 05:54 AM
ferret's Avatar
Car Model: Impreza Ltd
I unplugged the "rear accessory power relay" and installed a jumper across terminals 2 & 4 of the socket in the car. This way the outlet in the console & rear are ALWAYS on. (Does NOT affect the Cigarette lighter socket by the ashtray)
I can recharge my cell phone, PDA and notebook even with the car off. I leave my cell or PDA in the front storage compartment, out of site, or the Laptop in the rear with the cover pulled. Works well.
Mine is an 04, The 06 may be in the same place. It is right above the Inside Hood release. The relay looks circular and has a reddish connector on the wiring harness. I simply unplugged it and put a jumper across pins 2 & 4 of the connector, then tapped it back, out of the way, to the wiring harness.
ferret is offline
post #3 of 42 (permalink) Old 02-01-2006, 06:26 AM
MountainBiker's Avatar
It is done that way to protect people from draining the battery. What if you buy the Subaru Accessory refrigerator and leave it plugged in? Your battery will be dead in a very short time.
I agree though, not very convenient.
2002 S 4EAT
SubaXtreme Sump Guard, Lift & Bullbar
215/65-16 General Grabber AT2
MountainBiker is offline
post #4 of 42 (permalink) Old 02-01-2006, 05:24 PM
Kevin's Avatar
Car Year: MY03
That's a nice simple fix ferret - thanks! (add to ever increasing "list') :-)
MY'97 Outback RIP
Kevin is offline
post #5 of 42 (permalink) Old 03-11-2006, 11:47 AM
nds
Car Year: 2019
Car Model: Forester Touring
relay on my 05
Just went looking on my 05 and found two round relays mounted on the left side of the block of fuses and relays above the hood release. Neither has a red connector. Can someone help identify which one is the "rear accessory power relay".
nds is offline
post #6 of 42 (permalink) Old 03-11-2006, 12:35 PM
#8 Post ho
SenorSubie's Avatar
Car Model: Subaru Forester
Pictures would be helpful..
99 AT-
wrx goodies
Subiegal Gauge Pod
SenorSubie is offline
post #7 of 42 (permalink) Old 03-11-2006, 02:56 PM
broadbean's Avatar
Car Year: 06
Car Model: XSL
Is there a way that supplies some back up power like a UPS does - some sort of large capacitor or battery - so it will eventually cut the power to the sockets off, without draining the car's battery? This will itself be charged while the car is running.
Australian MY06 Regal Blue XSL Auto
broadbean is offline
post #8 of 42 (permalink) Old 03-11-2006, 03:03 PM
Kevin's Avatar
Car Year: MY03
I have a second battery for running the fridge etc. For additional power this is probably best. I do like ferret's solution for low drain, recharging of laptop, pda / gps, cell phone etc.
MY'97 Outback RIP
Kevin is offline
post #9 of 42 (permalink) Old 03-11-2006, 04:42 PM
ferret's Avatar
On the MY04 it is a red connector. It is the LOWER of the 2 relays. the one closer to the Hood Release. Try unplugging it then see if with the key 'on' you lose power to the outlets to verify on newer vehicles that this is the same relay. If it is just jumper Terminals 2 to 4 and maybe you can tell everyone else what color the connector becomes on the newer models.
ferret is offline
post #10 of 42 (permalink) Old 03-12-2006, 02:07 PM
nds
Car Year: 2019
I did it.
Ok, I did it on my 05. It is the lower round relay. The connector looks white to me but then my color vision is not perfect. The terminals to jump on the connector are numbers 3 and 4, and not 2 and 4. That is based no the markings on the relay that has two diagrams. One diagram shows the numbering pattern of the terminals, and the other is the operational diagram for the relay. A piece of advice. Make sure you tape up the jumped connector very good before you start moving it around. Real easy to hit a ground with it.
nds is offline
post #11 of 42 (permalink) Old 07-31-2006, 05:04 AM
Has anyone tried this on an '06?
dmcrane is offline
post #12 of 42 (permalink) Old 07-31-2006, 07:03 AM
BigAl's Avatar
Car Model: Forester L.L. Bean
Transmission: yes
Here's a solution to this problem - a device that will cut the power when the voltage falls below 11 volts: http://koolatrononline.stores.yahoo....ery-saver.html
2006 L.L. Bean Evergreen Metallic ("green Bean")
BigAl is offline
post #13 of 42 (permalink) Old 07-31-2006, 07:33 AM
Car Year: 2018
Car Model: 2.5i Premium
Looks useful.
$34 shipped on eBay (Buy it now) at http://tinyurl.com/zmxzj vs. $43 at the link in the above post.
bbottomley is offline
post #14 of 42 (permalink) Old 12-21-2006, 12:22 AM
Mudhoney's Avatar
Car Year: 13
hi. I'm thinking about having a go at this too. I have a MY06. I just need to clarify; it's the lower round relay, seems like pins 3 and 4. Do I pull it out, bridge the pins, then plug it back in, or not plug it back in? It seems I have to remove part of the plastic surround under the steering wheel to get access.
Mudhoney is offline
post #15 of 42 (permalink) Old 12-21-2006, 09:53 PM
broadbean's Avatar
Car Year: 06
Car Model: XSL
And here's one from Waeco.
