Weird starting problem - Subaru Forester Owners Forum
 6Likes
post #1 of 18 (permalink) Old 05-18-2019, 12:22 PM Thread Starter
Car Model: forester sti
Evening all
Ive got a strange starting issue .
Since I got my Bucket seats I have often started the car without getting in it e.g putting my foot on the clutch from outside with the door open and turning the key and boom it would start , I do this so I can then potter about in the garage whilst It warms up . this means I don't have to actually climb into the seat to start the car.
But now the car wont start in this way . Now I have to climb into the seat depress the clutch to make it start .
Any ideas?
I have Dyslexia, if you don't like my spelling go @&%# #@*?$
Lockheed is offline
post #2 of 18 (permalink) Old 05-18-2019, 12:46 PM
poffer's Avatar
Car Model: Forester XTE
Transmission: 5 speed manual
When you sit in it to start it, do you have the door closed? If it needs the door closed before it will start, I would guess it’s to do with the alarm/immobiliser restricting it in some way.
poffer is offline
post #3 of 18 (permalink) Old 05-18-2019, 01:17 PM
TMX
Car Year: MY05
Car Model: Forester 2.5 XT
Maybe pushing on the clutch pedal has allowed it to develop some "play" in the mechanism and so doesn't always hit the clutch pedal switch?
And now needs to be correctly aligned to hit the clutch pedal switch thingy, that sitting in the seat and pressing, happens to allow?
Just a guess
Don't have this problem with UK models, they start fine without pushing the clutch pedal - Or mine does anyway
TMX is offline
post #4 of 18 (permalink) Old 05-18-2019, 01:18 PM Thread Starter
I did wonder about that but why could I do it before and not now and why does it always start when im in the seat .
I have had a couple of instances where the starter motor has just spun but not flung its self out to engage the flywheel literally twice in the last 2 months but only when sat in the seat.
I have changed the battery in the fob so could the alarm be doing this after 3 years of good service ?
Lockheed is offline
post #5 of 18 (permalink) Old 05-18-2019, 01:28 PM Thread Starter
Just a guess
Yes that might make sense as when out of the car the pedal will be pushed at strange angle. what blooming idiot would modify a perfectly good car to the point where he doesn't want to get in it to start it ?
Kevin, TMX and Busaru2016 like this.
Lockheed is offline
post #6 of 18 (permalink) Old 05-19-2019, 10:18 AM
asdrewq's Avatar
Car Model: Forester STi
Sound odd - could be a dodgy switch needing full force of you sitting in the seat to connect. You can bypass the clutch switch for info with no ill effects - just bridge the connector with some suitable wire & tape up.
Lockheed likes this.
asdrewq is offline
post #7 of 18 (permalink) Old 05-19-2019, 12:53 PM
highland forry's Avatar
Car Model: FSTi
Transmission: 6 speed manual
Do you always depress your clutch on start-up? I only ever when I'm in the seat by a force of habit but when I'm outside the car like you do to let her warm I don't and never have.
Seems an odd one there bud.
Sook mah baws peasant
highland forry is offline
post #8 of 18 (permalink) Old 05-19-2019, 01:37 PM Thread Starter
Because its forged and there is a lot of piston slap when cold it takes a few minutes to warm . does yours start without the clutch down ?
Lockheed is offline
post #9 of 18 (permalink) Old 05-20-2019, 05:25 AM
Car Model: FSTi
Oooooh I see and yup it sure does. I'm not a guru but surely oversized rings would sort out any slap.... Oh hang on I'm guessing yours maybe a 2.1 stroker? So that would mean it's a bored 2 ltr... No? So would have oversized rings anyway?
So many questions.... 🙂
Edit: Maybe just forget everything I'm on about as I don't really know what I'm on about.
So generally the JDM cars need to have the clutch pedal pressed to start? I didn't know this as mine doesn't. Maybe thats why there's a wire loop on the clutch switch behind the pedal on mine. Well you learn something here everyday... Cue embarrassed face.
Looks like the connector has been disconnected and a loop put in.. See pic.
post #10 of 18 (permalink) Old 05-20-2019, 08:24 AM Thread Starter
Andy thanks for that I may have to do the same thing ,
The engine is an ej 22t with a 2.5 arrow crank so stroked to 2.35 its exactly the same bottom end as the Lateral Banana car built by the
same guy Paul Finch so in theory its capable of 850hp ……. the bottom end that is not the top end as Engine tuner proved .
as far as I know all jdm cars need the clutch depressed to start and all have indicators on the wrong or right side depending on your viewpoint also they have that annoying reverse beeper and sedans have rear window wipers .
Lockheed is offline
post #11 of 18 (permalink) Old 05-20-2019, 08:44 AM
Car Model: FSTi
Ah I see and wow.
Yes I'd give the loop between the male connector/female spades a shot as shown in the pic. Obviously whoever done it in mine found the correct female connector/male spades like on the clutch switch to make it look tidier and less chance of the spades getting caught and falling out. less hassle than having to stick a foot in the car or having to sit in to start her.
I also read a few things on the slap and forged pistons so kinda know a wee bit more than I did earlier haha. More silicone in the metal when forging causes less slap when cold.
post #12 of 18 (permalink) Old 05-20-2019, 08:48 AM
Car Model: FSTi
Yup indies on the opposite side and yup that annoying reverse beep, also key in the ignition and door open beep too. I've found both the culprits under the dash as it happens when taking that pic so may have to at least disconnect the key in ignition door open beeper as it's just so annoying.
post #13 of 18 (permalink) Old 05-20-2019, 10:30 AM Thread Starter
Just a guess
The problem is definitely this ^^^^ sitting on the bolster pushing the clutch at a less acute angle the car starts .
so problem solved .
Lockheed is offline
post #14 of 18 (permalink) Old 05-20-2019, 01:38 PM
TMX
Car Year: MY05
Are you sure all Japanese cars have that? I don't remember the R33 GTR having that........It did need the clutch pushed in to start and had the rear wiper and indicators on the opposite side...
Glad you figured it out, from another who stands next to the car to start it before getting in.
TMX is offline
post #15 of 18 (permalink) Old 05-21-2019, 12:04 AM
don1952's Avatar
Car Year: MY11
Car Model: WRX STi Sedan
Transmission: 6MT
AFAICR the reverse beep is inside the BIU unit.
"Back in the day" this has been looked into but once again the forum search facility is NBU again.
However eventually found it...
https://www.subaruforester.org/vbull...se-beep-80124/
don1952 is offline
Similar Threads
('09-'13) New to Subaru - starting problem? Kespectrum Problems, Maintenance, and Warranty 2 09-23-2016 08:16 AM
Weird rear drivers side window problem thammel Glass: Windows, Mirrors and Moon roofs 1 05-20-2015 03:17 AM
('14-'18) Weird drivers window problem thammel Glass: Windows, Mirrors and Moon roofs 6 04-24-2015 04:31 PM
('03-'05) Problem Starting When Cold chong EJ25 - 2.5L Non-Turbo (1998-2010) 15 01-05-2015 05:17 AM
Overnight starting problems. McGruff Problems, Maintenance, and Warranty 28 04-24-2006 09:58 AM
