('06-'08) How to fit 5x114.3 2011 STi Wheels on your 5x100 Forester (don't try this at home) - Subaru Forester Owners Forum
post #1 of 215 (permalink) Old 03-26-2012, 09:46 AM Thread Starter
FXTSPORTS08's Avatar
Car Model: Forester XT Sports
Feedback Score: 12 reviews
Disclaimer: Any modification done to wheels is potentially dangerous. If you do not know what you are doing then please do not
attempt. I have had no issues with the strength of my wheels but your results may vary. I am not responsible for anything that may happen to your
wheels or your car if you attempt this same modification. Don't try this at home!
Ok, so I was looking for wheels to put on my forester for this summer. I definitely wanted something wider than 7" and wanted something that had a
nice and clean OEM look. I really liked the look of the 2011 STi wheels made by Enkei. The problem was that they were 5x114.3 and also they were +55
offset which would most likely have some fitment issues with rubbing the struts. Thats when I went to look around and see what the thinnest adapter
I could have made would be.
I found a shop (motorsport-tech.com) that would custom make me 5x100 to 5x114.3 adapters down to 15mm. Using these adapters it would set the
wheel up to basically be a +40 18x8.5 which after some research looked to be quite optimal.I did a lot of measuring to see if the wheels would clear
the 5x100 studs. I also found some pictures of the 2011 STi wheel mating surface. This showed that it had large and deep pockets between the stud
holes. I had hope that I could pull it off!
Here are the adapters I had made, they are both hub centric and wheel centric:
I went ahead and bought the wheels and gave them a test fit. Unfortunately I still had some clearance problems! The lug nuts on the 5x100 studs hit the
sides of the pockets in the wheels:
After all the measuring I did I knew this might be a problem so I already had Plan "B" ready to go. I got out an air grinder and a spherical burr bit. I was
going to CNC the pockets but that would have taken a lot of time to mount the wheels and indicate them in. So I just carefully enlarged the pockets by
hand. I chose the spherical burr bit to reduce stress risers as it makes a really nice inside radius on the pockets:
The factory lug nuts are definitely too short to use with the extended studs the spacers came with but luckily I had thought about that and had a new
set of McGard two-piece spline drive lug nuts ready to go on!
Final specs:
2011 STi Enkei Wheels
18x8.5 +40
245/40-18 Dunlop SP Sport 600
Pic showing what the offset looks like compared to the fenders:
Here are some pics of the wheels on the car:
DGM '08 XT Sports 5MT
Check out my
FXTSPORTS08 is offline
post #2 of 215 (permalink) Old 03-26-2012, 10:22 AM
Car Model: xt
Transmission: old
A-Mazing!
I really think this looks good.
And has me thinking about converting spacers.
Can't shaving out parts of the wheel throw off balance?
soundsofsnow is offline
post #3 of 215 (permalink) Old 03-26-2012, 10:27 AM Thread Starter
Originally Posted by soundsofsnow View Post
A-Mazing!
Yes, technically but not really an issue. I did it very evenly, but also the closer the weight is to the center of the wheel the less it effects the balance. They put the weights all the way out towards the edge to maximize their effectiveness. Even if I did change the balance ever so slightly it is probably under the minimum weight increments due to how close to the center it is.
If I did feel there was a balance issue it would also be really easy to fix with one trip to a tire shop.
Check out my
post #4 of 215 (permalink) Old 03-26-2012, 10:27 AM
Snoshado's Avatar
Car Model: STI
Transmission: 6MT (2005)
This is so awesome dude...
I might be sending you some PMs asking for details if that's alright? I don't want to do a 6-speed swap but I've always wanted that bolt pattern.. <3 Great job! You car looks sweet!
Snoshado is offline
post #5 of 215 (permalink) Old 03-26-2012, 10:36 AM Thread Starter
Yeah go for it, I will gladly share anything I can to help with.
Check out my
post #6 of 215 (permalink) Old 03-26-2012, 10:41 AM
flyer27's Avatar
Wheels look awesome! (so does that rest of the foz) nice work!
flyer27 is offline
post #7 of 215 (permalink) Old 03-26-2012, 11:22 AM
Eggs's Avatar
Car Model: forester xt 5mt
do you think a 17mm adapter would fix the issue as well?
it seems like its so close
Eggs is offline
post #8 of 215 (permalink) Old 03-26-2012, 11:26 AM Thread Starter
I would say it would be more like an 18 or 19mm adapter. If you call Motorsport-Tech they will tell you exactly what will clear and what won't. I highly recommend talking to them if you are thinking about doing this, they really seem to be on the ball, their main business is custom adapters.
On my car even an 18mm adapter would be too big, 15mm was pushing the limits of what I wanted to run and how I wanted it to look.
Check out my
post #9 of 215 (permalink) Old 03-26-2012, 11:39 AM
max6spd's Avatar
Feedback Score: 41 reviews
Ooohh...I want to do this. So all you really need to do is have enough clearance to clear the lugnut, right?
max6spd is offline
post #10 of 215 (permalink) Old 03-26-2012, 11:40 AM Thread Starter
Well yes and enough depth to clear the studs. The pockets on the back of the 2011 STi Enkei wheels were deep enough to clear the studs just not wide enough to clear the lug nuts.
Check out my
post #11 of 215 (permalink) Old 03-26-2012, 11:48 AM
Snoshado's Avatar
Car Model: STI
Do you think if I called up Motorsport-Tech and asked them for exactly what you bought, they could set me up? And do you remember how much you paid for this?
Snoshado is offline
post #12 of 215 (permalink) Old 03-26-2012, 11:53 AM Thread Starter
Yeah, just call them up and tell them what you are doing, they have all the specs. They knew what the hub and wheel center diameters were and everything. They make it real easy. They won't be able to tell you if the wheels will clear the 5x100 studs/nuts though because every manufacturer and style of wheel is very different.
I paid $285 shipped, that was $240 for the spacers, $20 for lug nuts to go on the 5x100 studs and $20 shipping.
They will make you cheaper spacers that are are not wheel centric but I wanted it to be right.
Check out my
post #13 of 215 (permalink) Old 03-26-2012, 03:08 PM
fourortwowheels's Avatar
Car Model: FSXT
Transmission: M/T
Feedback Score: 13 reviews
What are your thoughts on a beefier 245/45 tire?
fourortwowheels is offline
post #14 of 215 (permalink) Old 03-26-2012, 03:10 PM Thread Starter
That is actually what I would prefer to have on my car right now, the 245/40 is just what came on the wheels. The wheels I got had 500 total miles on them and the OEM tire, the price was right!
Check out my
post #15 of 215 (permalink) Old 03-27-2012, 06:31 AM
Eggs's Avatar
what if the lugs were recessed like this?
make a difference?
Eggs is offline
