('14-'18) 20mm Rear Sway Bar - Page 2 - Subaru Forester Owners Forum
 19Likes
post #16 of 29 (permalink) Old 03-28-2018, 01:30 PM Thread Starter
securityguy's Avatar
Car Year: 2019
Car Model: Forester Sport
I agree with what everyone said about adding the 20mm bar. It tightens up the rear and has a more solid feel without compromising ride quality. For a $100 and an hour in your driveway it is well worth the investment. Did this to my 2015 Legacy too and was very pleased. Highly recommend!
2019 Sport
Subaru Ambassador
securityguy is offline
post #17 of 29 (permalink) Old 03-29-2018, 06:30 AM
rollin wes's Avatar
I also went with the 20mm bar. I installed mine about 4 months ago and it has made me much happier with the handling. The car just feels more planted in all situations. I got to test it out on a trip up to the mountains recently and the handling on curvy roads is way better. It leans less and I found it easier to make small steering corrections.
jdac85 likes this.
SC Fozy
rollin wes is offline
post #18 of 29 (permalink) Old 03-29-2018, 11:11 AM
SyrForester's Avatar
Car Year: 2018
I can't wait to get mine on!
It has been sitting in in the back of my Jeep (which has both of its swaybars permanently removed) waiting for time to install.
Hopefully in a few months I can get it in
SyrForester is offline
post #19 of 29 (permalink) Unread 04-21-2019, 08:40 PM
SoobADoob's Avatar
Car Year: 2018
Car Model: Premium 2.5i 6M
What is people's experience with the 19mm or 20mm off of paved roads? I live around a number of US Forest Service roads that I drive in during the hiking season. Not anything involving rock crawling, though; I usually drive in 2nd or 3rd gear. How would either of these affect these drives, if at all?
SoobADoob is offline
post #20 of 29 (permalink) Unread 04-22-2019, 06:21 AM
Maxwedge's Avatar
A stiffer suspension, and the RSB in this instance, will make off-roading less gooder. The 16mm bar Subie installs is a compromise, to satisfy the most people. It allows reasonable and comfy handling on the highway and still flexes enough for rough terrain. The stiffer you go, the less the wheels will be able to keep contact with the dirt road. I have a 22mm on the rear and it holds the car very stable at high speed on the highway, but on a rutted fire road I would be 3-wheeling it over holes.
I don't have any rough-ground experience with mine, other than flat fields and gravel lots. Maybe someone with a built off-road Fozzy can comment. For dedicated trail use I'd think a soft bar, or none at all, would be best. My cousin has quick-disconnects for the sway bars on his jeep. When he gets to the trail head he disconnects the bar from the axle and ties it up, for the easiest flexing. That would be bad on the highway though, so You'll need a happy medium.
Maxwedge is offline
post #21 of 29 (permalink) Unread 05-07-2019, 07:58 AM
jlx21's Avatar
Car Model: 2.0XT Touring
Planning on getting the 20 mm from subaru. What tools do i need? I'm hoping i can just lay down in my garage to install without jacking the car up...
jlx21 is offline
post #22 of 29 (permalink) Unread 05-07-2019, 10:13 AM
Car Model: 2008 2.5i-2018 XT
Just a socket wrench. Forget the size. Biggest challenge is maneuvering out of where its installed. And thats not very hard.
adc is offline
post #23 of 29 (permalink) Unread 05-07-2019, 12:14 PM
HeyChris's Avatar
Car Year: 2013
Car Model: F-XT
To give you an idea of how much stiffer a larger bar is....
In case picture goes away some time down the road....
http://www. subaru4you.co .uk/images/parts/suspension/whitelineswaybarstiffness.jpg
CrystalPistol likes this.
HeyChris is offline
post #24 of 29 (permalink) Unread 05-20-2019, 10:33 AM
CrystalPistol's Avatar
Car Year: 2019
Looked under 19, not near same bar.
...and do have a Safe Trip!
CrystalPistol is offline
post #25 of 29 (permalink) Unread 05-29-2019, 07:25 AM
CGumina's Avatar
I did the 20mm rear sway bar on our '17 Forester this past weekend, and boy, what a marked improvement it was over the stock unit.
Install took about 45 minutes, mostly due to fighting the slightly-crusty end links out of the lower control arms. On a difficulty scale, I would rate it a 2/10. All that was required was a set of metric allen wrenches, 14mm box end wrench, and a 17mm box end wrench.
While it's not exactly a "canyon carver", the tossing the thing around a little on the twistier back roads was far more fun. Stability was better, and everything felt less top-heavy due to the reduced roll out back. I didn't note any change in ride comfort that could be quantified, and the fit/finish of the bar was perfect, as you'd come to expect from an OE Subaru part. For $88, you would be very hard pressed to find an easier modification to do with such a large, positive impact.
Maxwedge likes this.
CGumina is offline
post #26 of 29 (permalink) Unread 05-29-2019, 03:01 PM
billshoff2's Avatar
Car Model: Forester Limited
2015 WRX rear sway bar will fit a 2015 Forester
I bought a used 20mm bar from a 2015 WRX on ebay for $30 and it took me 45 minutes to install. Well worth doing.
Name:	20mm rear sway bar from 2015 WRX on ebay $50.jpg
CGumina likes this.
billshoff2 is offline
post #27 of 29 (permalink) Unread 06-09-2019, 08:06 AM
Car Model: Forester 2.5i
Quick question: Are you talking about an OEM swaybar that I would buy at the Subaru dealership?
2015espy is online now
post #28 of 29 (permalink) Unread 06-09-2019, 08:31 AM
You can try and find a used one or buy new from one of the Forum parts vendors. Think they are around $85 new.
Steel City Subi is online now
post #29 of 29 (permalink) Unread Today, 12:47 PM
As an FYI for anyone out there, Subaru Online Parts sent me a quote of $76 for the bar and bushings and $25 for delivery to SF bay area from NY. If you live on the east coast, this becomes a great buy for a new Subaru part.
