('09-'13) Oil consumption after new heads installed - Subaru Forester Owners Forum
 2Likes
  • 1 Post By leland grant
  • 1 Post By karlaudi
post #1 of 7 (permalink) Old 05-11-2019, 05:33 AM Thread Starter
doug883's Avatar
I've recently had the heads, head gaskets, and valve cover gaskets, along with a few other parts replaced. Before the work was done, I would use about 2 quarts of oil between oil changes. Now, it's using 1 quart every 800-1000 miles. The engine shows no signs of leakage, but my chrome exhaust tips are black, so it's obviously going into the combustion chamber. I'm assuming it's the rings. Is there anything else that could cause this, like the pcv valve?
doug883 is offline
post #2 of 7 (permalink) Old 05-11-2019, 05:56 AM
a stuck closed pcv or slow to open will generally cause oil loss thru leaks when at higher rpms, as crankcase internal pressure build sup, pushing pressurized oil laden gases out past gaskets and seals, ,if your head gaskets are good , and no cracks,.............. then it can often be valve guides that allow oil loss into the combustion chamber,, . valve guides can be a weak spot in subarus, and if they were not replaced or at least re-knurled during the head work, or damaged during that work , then they may be the problem, ..............other than changing oil to something stickier, [ your 09 should probably run a conventional 5w30 weight oil such as valvoline] than i would say it needs to be examined in detail. , which wont be cheap , ...................new solid head surfacing and gasket can cause a higher level of vacuum, which can draw oil into and past rings to combust too if the rings and guides are worn
Miker104 likes this.
leland grant is offline
post #3 of 7 (permalink) Old 05-11-2019, 06:30 PM
karlaudi's Avatar
Transmission: 5-speed manual
Even on a healthy gasoline engine there will be soot at the tailpipe. My 2012 VW Touareg TDI had a spotless tailpipes at 148,000 miles thanks to low sulfur diesel fuel and a particulate filter. Particulate filters are coming on line in Europe for gasoline cars because they have soot too and theirs is finer diesels. It is also why the VW Group and other European manufactures are very specific about motor formulations for their cars.
Why did you have the heads done? Was a compression test done and if the readings were out of specifications was a leak down test done to confirm why the leakage was occurring with the combustion chamber / cylinder before rebuilding the heads? Has a compression test been done since the head work was done to confirm the compression reading are within Subaru's specifications?
A four gas exhaust analyzer or similar "smog machine, can help confirm if you are burning oil by measuring the amount of unburned hydrocarbons that are in your exhaust gases. If they are well above what one would expect from normal or overly rich fuel mixture, along with other indicators, then indeed you may be burning oil.
If a compression test and leak down test show that your rings, head gaskets, and valve seats are OK, I would expect failed valve stem seals either because they were reused, the wrong ones, or new ones were damaged during install and /or what leland grant said about the valve guides.
I would disagree with Leland on the use of conventional oil , especially if you are burning oil. Subaru has in my view very simple oil requirements compared to some other manufacturers.
But if we are really worried about burning oil until the problem is solved, I would use a synthetic oil SAE 5W-30 that meets (stated on the bottle) VW Oil Quality Standard VW504 which are..."according to this Standard are optimized for high cleanliness of the intake area of direct injection gasoline engines, ensure the required service life of exhaust aftertreatment systems....". Such a SAE 5W-30 oil that meets VW504 oil quality standards may not meet the API SN and ILAC GF-5 specifications Subaru recommends, however, such as Castrol EDGE Professional LongLife III 5W-30, as just one example. The goal here is to have a motor oil that will burn very clean in the combustion chamber.
Yet, even my suggestion is splitting hairs with Leland, as the real problem is that it would appear, post rebuilding your cylinder heads, that your oil consumption has dramatically increased and the type of motor you are using is not likely to be the source of the problem nor the cure.
karlaudi is online now
post #4 of 7 (permalink) Old 05-12-2019, 12:38 PM Thread Starter
doug883's Avatar
We put the car in because of the notorious head gasket problem, only to find out the heads were warped and needed to be replaced. I'm sure the valves and valve guides are original, and I doubt they did a compression test. We were told at 100,000 miles about the head gasket, but didn't have the money to fix it. We finally did now, at 170,00 miles. To be honest, the engine is running great, it's quiet, getting around 25 mpg. I was thinking of going to a 5w40 synthetic to see if that would help. I was also wondering if an air-oil separator would be beneficial.
doug883 is offline
post #5 of 7 (permalink) Old 05-12-2019, 05:06 PM
Miker104's Avatar
Car Model: Forester X
Transmission: 5 MT
Change the PCV valve with a Subaru part before you do anything else. If new heads were installed (remanufactured?) new valve stem seals would have been installed.
We did have an engine that we put a new short block in that consumed oil and it was a damaged valve stem seal.
Miker104 is offline
post #6 of 7 (permalink) Old 05-12-2019, 08:03 PM
karlaudi's Avatar
API: SN, ILAC GF-5 "Resource Conserving" SAE 5W-30 weight oil is what is recommend by Subaru, as API: SM is obsolescent and ILAC GF-4 has been replaced by GF-5. 10W-30 and 10W-40 oil meeting the same specifications are suitable alternatives as per your Owner's Manual and the Repair and Service Manual.
I have been a long time VW / Audi owner and for more than two decades the VW Group has set its own quality standards for motor oil used in its various engines throughout the group, as I have previously mentioned. Subaru has less specific requirements than the VW Group, currently, but they still have oil standards.
I would use only an oil that meets those standards. API class SM is obsolescent and was replaced with backward compatible SN oil. There are actually three versions of API "SN" classification oil and one of those is "Energy Conserving". Oil consumption varies widely, based on a given engine design and its operating environment at any given time.
So, as a baseline to try to solve this problem. I would use, if you are not already doing so, a brand of oil your prefer, conventional or synthetic (Subaru does not specify which one, so your choice), that specifically states the following somewhere on the bottle:
SN, 5W-30, GF-5, and "Resource Conserving".
Please keep in mind that the SAE viscosity recommended, and the alternatives, are based on the ambient temperature ranges Subaru expects their cars to operate in during start up. The additive packages found in the oil and the base stock used will determine the actual behavior of the oil at normal operating temperature within the engine.
An air-oil separator should not be needed on your or any other stock street car operating normally. Yes I am aware of the reported issues in gasoline direct injection engines and other modern engine designs. I understand that others believe they are necessary and in racing applications I would agree for the need, but a racing motor, even one based on a stock motor, is different than that used on the street.
In the case of your EJ motor - or mine - if you have sufficient crankcase blow-by to overwhelm a correctly functioning PCV system, then I would focus on correcting the problem rather than mitigating the symptoms of the problem.
Your engine ran fine for 70,000 after being told to renew the head gasket, as I understand. Not a bad thing. Finding an aluminum cylinder head warped with such mileage when renewing the head gasket is not unusual and it is not uncommon to find on any high mileage engine. Resurfacing the head gasket mating surface on a cylinder head, as a matter of course, warped or not, is not uncommon either.
How long in terms of both time and miles has it been since the work was done? Is there any evidence of an external oil leak anywhere on the engine?
You state that, except for the oil consumption concern, your engine is running and performing well.
When you state the heads were replaced, were your specific heads rebuilt? Or exchanged with another pair that were rebuilt or re-manufactured? Or did the shop that R&R your heads do the rebuilding of the heads themselves with the possible exception of having a machine shop resurface the head gasket mating surface, or other work like replacing the valve guides?
Given the tight confines of the Subaru boxer motor in the engine compartment of their cars, doing a compression test and a follow up leak down test is more time consuming, but not really more difficult than removing the spark plugs in the first place. I would certainly do both these tests moving forward, if for no other reason than to establish a baseline of your engine's current health.
The late 1970s through early 1990s was a period of rapid changes in motor oil and diesel and gasoline fuel formulations, both here and in Europe. One of the unexpected problems that occurred during this period was that rubber seals used in engines already in service failed. The causes varied through this period, but one of the results was the change to the use of Viton brand rubber in O-rings, radial seals, and especially valve stem seals. In the case of VW /Audi valve stem seals, the characteristic of Viton rubber valve steam seals is they are a olive or slug green in color. The green was the give away that they were not identical seals made without Viton.
Leaking valve stems can also contribute to poor manifold vacuum and can be in part diagnosed with a vacuum gauge. Valve stem seals, are a type of radial seal. They control the amount of engine oil that must flow toward the intake and exhaust ports to lubricate the valve stem as it moves inside the valve guide. If the seal is hard and brittle or cracked or damaged in such a way that the flow of oil exceeds the designed in rate of flow, then the engine will exhibit increased oil consumption.
In spite of not knowing at this time what exactly was done to your heads, how long ago the work was done, and the some total of the parts used and their quality, I am in the end making a guess as to what the source of your old consumption is. I lean toward the valve stems. They can be replaced without removing the heads. However, head gaskets seem to be the common and reoccurring weakness of Subaru boxer motors. Head gasket failures is real world usage is not unique to Subaru.
Years ago with the motors used in MkI and MkII VW Golfs, for example, head gasket failures in motors rebuilt with aftermarket OE/OEM head gaskets was attributed to the composite gasket being too "old", dried out, hard and "stale". The idea being that fresh recently produced head gaskets were visibly moist and somewhat pliable. At time, at least the OEM manufacturer Goetze made the head gaskets that one would purchased at VW Dealers. Goeteze packaged their head gaskets inside thick heavy duty high density polyethylene plastic bags that were hermetically sealed along with a cardboard backing to support the gasket. Other suppliers the aftermarket and the “gray market” imported from NOS supplies and other sources, shrink wrapped theirs like a typical retail product. For years now, the VW Group has adopted the practice of using "Use By Dates" on spare and replacement parts that have an actual shelf life including head gaskets.
As I understand things, the weakness of Subaru head gaskets is the design itself. There apparently is a new Multi-Layer Steel (MLS) that many gasket manufactures like Mahle, Fel-Pro, 6-star produce, to name a few.
Yet, there is at least one author of a YouTube video about Subaru head gaskets that points out that the best MLS gaskets retail for about $50.00 each but, they also note one can find conventional composite gaskets for Subarus on the aftermarket for about $15.00 each. An example one of those composite gaskets they show on there video as having failed after just 2,000 miles.
In trying to solve your oil consumption problem I would use the quality and grade of oil Subaru recommends and I would focus on proven diagnostic practices to determine the true health of your engine. Hopefully, your problem will be resolved that way.
Good Luck!
post #7 of 7 (permalink) Old 05-15-2019, 08:29 AM Thread Starter
doug883's Avatar
Well, since the repairs that the dealership did comes with a 12 month/12,000 mile warranty, they want the car back to see why it's using so much oil. I'll keep y'all informed with what they find. Thank you for all of your input!
doug883 is offline
Similar Threads
Synthetic Motor Oil Discussion Duck Engine and Exhaust 276 08-10-2018 08:01 AM
waali's GT: MY02 GT SF5 waali Members' Journals 140 01-29-2018 08:24 PM
FB Series Engine, Oil Burning, Subaru, and You gbmaryland FB25 - 2.5L Non-Turbo (2011- 2018) 15 03-14-2017 08:21 AM
So California Parts, Install, Maint/Service, Repairs, Mods, Dyno Tuning Infamous Performance Supporting Vendors 119 10-21-2015 08:30 AM
Oil FAQ GIT-R-DONE Problems, Maintenance, and Warranty 35 07-15-2010 12:17 PM
