('03-'05) High coolant temp - Subaru Forester Owners Forum
post #1 of 3 (permalink) Old 05-26-2019, 05:14 AM Thread Starter
Car Year: 2013
Car Model: Subaru STI
Transmission: 6 Speed Manual
High coolant temp
2004 XT 5speed
Lately I’ve been getting higher than normal coolant temps. It has been reaching ~225 (highest 227). The radiator fans work and this morning is the first time the overflow spilled over. The heater blows hot as well. I am suspicious of the T-stat. My one confusion is when the fans kick on the temp starts to go down when at idle but when driving temp goes back up. Any advice would be greatly appreciated.
Dmojica is offline
post #2 of 3 (permalink) Old 05-26-2019, 06:25 AM
change thermostat .use oem only . check temp sending unit , either it is getting hotter than the gauge says , or not, this can be fan delay,................ thermostat stuck partially shut .................., weak water pump ..............internally collapsed hose, or bad head gasket, after thermostat change out if it still then run compression test and gas exhaust in coolant check.................. it is more rare , but a weak oil pump can cause overheat too
leland grant is offline
post #3 of 3 (permalink) Old 05-26-2019, 06:38 AM Thread Starter
Car Year: 2013
@leland grant Thank you for the advice!
What fluid would be closest to OEM? I am away for work and have an autozone nearby but no Subaru dealer. I am planning on getting a T stat there as well till I can get an OEM Subaru one.
Dmojica is offline
  Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Engine and Exhaust > Cooling Systems
Similar Threads
('06-'08) Coolant temp & other issues TonoAlpha Problems, Maintenance, and Warranty 1 02-25-2017 08:36 PM
('09-'13) 2010 Diesel... operating temp and losing coolant Tvilleguy EE20 - 2.0L Diesel 13 01-16-2017 09:22 PM
('14-'18) What are the normal temp ranges for coolant and oil? Sweaty FA20DIT - 2.0L Direct-Injection/Turbocharged (2014+) 45 12-29-2016 10:13 AM
('14-'18) Low Coolant on XT Barking Trout FA20DIT - 2.0L Direct-Injection/Turbocharged (2014+) 47 01-10-2016 07:17 PM
('98-'00) P1520: Coolant Fan Relay 1 High Input. kberube Lighting and Electrical 4 03-31-2015 06:59 PM
