So California Parts, Install, Maint/Service, Repairs, Mods, Dyno Tuning - Subaru Forester Owners Forum
post #1 of 120 (permalink) Old 04-14-2015, 12:55 PM Thread Starter
Infamous Performance's Avatar
Car Model: Forester XS
Shop located in Escondido. Full fabrication services available. Specializing in Subarus. No job too big or small.
Address is:
1948 Don Lee Place, Suite 8
Escondido, CA 92029
Check us out of Facebook:
https://www.facebook.com/pages/Infam...6553829?ref=hl
Check us out on Yelp:
Infamous Performance and Tuning - Auto Repair
Phone: 760-781-1126
email: [email protected]
Please call for appointments.
For custom work we charge $95 per hour plus materials. For standard things we will quote a price.
Some basics we get lots of request for;
Fender rolling
$50 per corner
Exhaust Install Pricing (Labor)
Headers $150
Headers Back (Headers, Uppipe, Downpipe, Axleback) $415
Headers & Uppipe (Headers, Uppipe & Downpipe Only) $400
Uppipe (Uppipe, Downpipe) $325
Uppipe Back (Uppipe, Downpipe, Midpipe & Axleback) $350
Downpipe Back (Downpipe, Midpipe & Axleback) $215
Downpipe (Downpipe) $200
Catback/Axleback $75
Hardened Exhaust Hangers $65
*Prices based on stock vehicles in good working condition and standard replacement parts (no major rust, broken bolts, etc) Non-Standard installs will be billed at our regular hourly rate.
Turbo Install Pricing (Labor)
Turbo/Injectors/Fuel Pump (W/No Air Pump and Side Feed Injectors) $760
Turbo/Injectors/Fuel Pump (W/Air Pump and Top Feed Injectors) $855
Turbo (Bolt in) $380
Injectors (W/No Air Pump and Side Feed Injectors) $285
Injectors (W/Air Pump and Top Feed Injectors) $380
Fuel Pump $95
IP&T SS Turbo Oil Line (w/Turbo Install) $95
IP&T SS Turbo Oil Line $190
Mounts & Bushings Install Pricing (Labor Only)
Motor Mounts $190
Transmission Mount $95
Anti-Lift Kit $200
Front Lower Control Arm Rear Bushings (Legacy '05+, Impreza '08+) $200
Front Lower Control Arm Inner & Rear Bushings (Legacy '05+, Impreza '08+) $250
Front Roll Center Kit (Legacy '05+, Impreza '08+) $190
Front LCA Bushings & Roll Center Kit (Legacy '05+, Impreza '08+) $260
Steering Rack Bushings $190
Rear Subframe Bushings $125
Rear Differential Locking Bolts $65
Rear Differential Mount Bushings $190
Short Shifter (5MT) $95
Short Shifter (6MT) $150
Short Shifter w/Bushings (5MT) $145
Short Shifter w/Bushings (6MT) $180
*Prices based on stock vehicles in good working condition (no major rust, broken bolts, etc)
Electronics Install Pricing
Electronic Boost Gauge $180
EGT Gauge $200
A/F Gauge $190
Oil Pressure/Temp Gauge (In Block, only avail on certain models) $190
Oil Pressure/Temp Gauge (Filter Style) $160
Electronic Boost Controller Grimspeed Style $65
Hella Horns $150
Hella Horns(Bumper Removal Required) $190
Services Included in our 30K Mile Service
Replacement of:
Coolant (Subaru Long Life) (Coolant Conditioner added on NA Cars)
Brake Fluid (Full Flush with ATE Type 200 or Standard Fluid)
Transmission Fluid (Subaru HP or Subaru ATF)
Front and Rear Diffy Fluid (Subaru HP)
Oil Change (Motul 8100 X-clean, Conventional – Subaru Filter)
Fuel Filter (if applicable)
Air Filter
Rotate Tires
NGK Spark Plugs (Non-Turbo Cars)
ACC Belts (Except H6 and 08+ WRX)
Clutch Fluid
Checks on: Brakes, Parking brake, Clutch, Suspension, Fuel lines, Exhaust
Pricing:
Turbo
30k Using Conventional Engine Oil & Subaru Oil Filter $440
30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $475
*On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles.
Non-Turbo – H6 add $70 (serpentine belt, oil)
30k Using Conventional Engine Oil & Subaru Oil Filter $485
30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
*On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
**On Forester $20 extra due to plug placement.
Services Included in our 60K Mile Service
Replacement of:
Air Filter
Rotate Tires
NGK Spark Plugs
Clutch Fluid
Pricing:
Non-Turbo Engines – H6 add $70 (serpentine belt, oil)
60k Using Conventional Engine Oil & Subaru Oil Filter $480
60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
Turbo H4
60k Using Conventional Engine Oil & Subaru Oil Filter $495
60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $540
*On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Filter Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
***On H6 Models $35 extra due to plug placement and quantity.
Services Included in our 90k Mile Service
Replacement of:
Air Filter
Rotate Tires
Clutch Fluid
Pricing:
Turbo
90k Using Conventional Engine Oil & Subaru Oil Filter $440 90k Using Subaru Synthetic or T6 Rotella Engine Oil & Subaru Oil Filter $475
90k Using Conventional Engine Oil & Subaru Oil Filter $485
90k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
Services Included in our Timing Belt Service
Replacement of:
Timing Belt
Timing Belt Tensioner
Timing Belt Pulleys
Water Pump
Thermostat
Coolant Flush
Timing Belt Service Pricing:
Turbo
Timing Belt Service $745
90k Service w/Timing Belt Service $695
Non-Turbo
Timing Belt Service $720
90k Service w/Timing Belt Service $670
Oil Changes
Motul 8100 X-clean 5w30 w/Subaru Oil Filter $80
Standard Conventional Oil 5w30 w/Oil Filter $35
Bring your own Oil/Filter Change $30
Coolant Changes
Subaru Long Life Coolant Drain/Fill $115
Subaru Super Long Life Coolant Drain/Fill (100k Blue Subaru Fluid) $140
Gear & Transmission Changes
Subaru 5MT Front Diff, Trans - Subaru HP $110
Subaru 6MT Front Diff, Trans - Subaru HP $125
Add Rear Diff $25
Subaru 4EAT or 5EAT ATF - Subaru ATF $125
Add Front and Rear Diff $60
Add Subaru ATF Spin on Filter $55
BRZ/FRS 6MT Trans – Subaru HP $95
BRZ/FRS Rear Diff $35
Misc Fluids
Full Brake Flush with ATE Type 200 $105
Water Wetter $20
5MT/6MT Clutch Labor
Clutch & Flywheel Labor Only $475
Add Front Diff, Trans – Subaru HP $65
5MT Flywheel resurface (single mass) $65
6MT Flywheel resurface $85
Misc Services
AC/Alt-PS Belts (Per Belt except 08+ WRX AC) $30
Spark Plug Replacement – Turbo (4) add $25 for OBXT/Forester $190
Compression Test – Turbo (4) add $25 for OBXT/For $225
Compression Test – Non Turbo (4) $140
Spark Plug Replacement – Non Turbo (4) $150
Springs/Shocks/Struts
Springs/Struts/Shocks (Labor Only) $220
Koni Sport Struts Inserts (Labor Only) $330
Coil Over Install and ride height set $330
CV Joints/Axles/Wheel Bearings
Drive Axle w/CV Joint (Labor Only) $95
Drive Axle w/CV Joint (Parts & Labor) $270
Sway Bars
Rear Sway Bar w/oMounts (Laborl Only) $95
Front Sway Bar (Impreza '02+, Legacy '05-'09) $95
Standard Engine Rebuilds
CP Forged Pistons w/Rings
King Bearings Rods
King Bearings Main
ARP head studs
11mm Sti oil pump
Timing kit w/water pump
OEM Gasket Kit
Bore/Hone w/torque plates
3 angle valve job, adjustment, resurface
T-stat
NGK plugs
Coolant
Oil
Oil Filter
Labor
$6000
Brakes
Standard Fluid Flush $60
ATE Type 200 Fluid Flush $105
ATE Fluid Flush + Stainless Steel Line install (02-07 Imprezza) $210
ATE Fluid Flush + Stainless Steel Line install (08+ Imprezza) $235
ATE Fluid Flush + Stainless Steel Line install (05-09 Legacy) $235
Front or Rear Pads Installed $100
Front and Rear Pads Installed $150 w/fluid flush $195
Front Rotors and Pads Installed $180
Front and Rear Rotors and Pads $270 w/fluid flush $310
Coolant Related Items
Radiator Replacement (Labor) $160
Accessory Related Items
Alternator (Labor Only) $95
Misc Items
Subaru Valve Cover Gaskets (Labor both sides) $380
Subaru Head Gaskets Non-Turbo SOHC Engines (Parts & Labor Estimate) ~$2,200
Subaru Head Gaskets DOHC Engines (Parts & Labor Estimate) ~$3,500
(If the Heads need reconditioning additional charges may apply)
Parking Brake Adjustment $45
Prices valid on stock vehicles in good working condition (no major rust, broken bolts, etc). Prices are labor only, materials extra (unless otherwise noted).
Infamous Performance is offline
post #2 of 120 (permalink) Old 04-15-2015, 10:54 AM Thread Starter
Half way through the month. 2 more weeks to take advantage of the Spring Sale. PM's replied. Thanks!
post #3 of 120 (permalink) Old 04-16-2015, 01:33 PM Thread Starter
Late Thursday bump. Busy like the bees. Thanks for keeping us busy!
post #4 of 120 (permalink) Old 04-17-2015, 04:08 PM Thread Starter
Made it to Friday. Have a great weekend. We will be shipping orders again on Monday. Shop is open tomorrow.
post #5 of 120 (permalink) Old 04-18-2015, 07:59 AM Thread Starter
post #6 of 120 (permalink) Old 04-20-2015, 04:36 PM Thread Starter
Busy weekend for online orders. We are packaging up the parts and emailing off tracking numbers as quickly as possible. Thanks for all the support! You still have 2 more weeks to save 10-25% by using promo code "Sale 15" at checkout.
More cars in the shop for service. 5th clutch in 6 days being installed today. 4 motors being rebuilt this week. When it rains, it pours.
post #7 of 120 (permalink) Old 04-21-2015, 10:26 AM Thread Starter
post #8 of 120 (permalink) Old 04-22-2015, 09:16 AM Thread Starter
Mid week bump for the Spring Sale.
post #9 of 120 (permalink) Old 04-23-2015, 06:16 PM Thread Starter
Very late Thursday bump. Busy day at the shop and we thank you all for keeping us busy. Save 10-25% off with promo code "Sale 15" at checkout.
post #10 of 120 (permalink) Old 04-24-2015, 09:29 AM Thread Starter
Final Friday of April. More orders shipping today. We are closed tomorrow. Have a great weekend!
post #11 of 120 (permalink) Old 04-27-2015, 10:05 AM Thread Starter
Final Monday of April bump.
post #12 of 120 (permalink) Old 04-28-2015, 11:24 AM Thread Starter
Happy Tuesday! Only 2 short days left in April. Take advantage of the sale now.
post #13 of 120 (permalink) Old 04-28-2015, 01:26 PM
Can you guys deck heads? Doing the head gaskets soon on my NA Forester and want the heads machined.
07 SG9 Forester X 5MT, 1" lift on 28" Cooper AT3's
glamisdude is offline
post #14 of 120 (permalink) Old 04-29-2015, 12:09 PM Thread Starter
We do not do them in house, but we can certainly send them over to our machine shop to have them resurfaced.
post #15 of 120 (permalink) Old 04-30-2015, 05:45 PM Thread Starter
Final day of the Spring Sale is today!
  Subaru Forester Owners Forum > Vendor Member Section > Supporting Vendors
