('06-'08) 2008 2.0d Stalled going up hill and oil light came on - Subaru Forester Owners Forum
post #1 of 4 (permalink) Old 04-15-2019, 12:46 AM Thread Starter
New User
Good Morning everybody.
OK so firstly my name is John and I am the owner of a Subaru Legacy 2.0d.
If I shouldn't be here as its a forester forum, I apologise and can someone please point me in the right direction as I can't seem to find advice anywhere. Thanks in advance.
OK so i recently bought a 2008 legacy 2.0d it seems to have been well looked after and serviced. It has about 180k kms.
On my second day of owning the car, I was driving on the motorway at about 120km/h. Whilst reining up a very long hill, I noticed the car hesitating and it finally cut out, like it had ran out of diesel. Sure enough I was getting low on fuel but my fuel light hadn't come on yet and the computer was saying I had 160 kms left in the tank.
Engine seemed fine and loose so I cranked the engine periodically and finally it restarted and drove fine.
About 15 kms later I got to a fuel station and as I came to a stop and pressed on the clutch, the oil pressure light came on and only turned off when I revved the car.
I refueled and started the car and everything seemed fine. A few kms down the road and the same thing happened as I approached a roundabout, as soon as I clutched and the rpms dropped, the oil light came on and stayed in a little longer and required a higher rev to turn it off.
I haven't driven the car since. Its sounds OK I think.
Any ideas of what's going on here? Is it the oil pickup that clogged so you think or is there an injector problem which is putting diesel into the sump?
Oil level doesnt really seem high though, it was when it was warm but once it cooled down it was the same Level I think.
I figured I'd drop the sump and clean the pickup, is this a good idea? Is it possible to do this without a lift an djust on axle stands?
I appreciate any help you could give me lads.
Thanks a million in advance.
Johnbatman520 is offline
post #2 of 4 (permalink) Old 04-15-2019, 03:07 AM
R5oss's Avatar
Car Year: MY09
Car Model: XSn 2.0 Diesel
Transmission: 6MT
Hello John, if it's a Subaru, we'll speak to you.
The oil light should be on at tick over without any need to rev it. Now as to why it's not, then low oil level might be the cause, but you need to investigate further.
As for the engine cutting out ?, it might just be due to low oil/pressure and the ECU responding to protect the engine. But who knows ?. Did the engine check light come on.
R5oss is offline
post #3 of 4 (permalink) Old 04-15-2019, 03:53 AM Thread Starter
New User
Hi R50ss.
Thanks for your reply!
I'm sorry but Its actually the oil pressure warning light that I'm talking about. It's usually off and only comes on when there is low pressure.
It was this light that came on when the rpms dropped in the engine.
Thanks.
post #4 of 4 (permalink) Old Today, 05:01 AM
Car Model: Forester Diesel
Transmission: 6MT
Hi John,
sorry for the late reply, been letting other things (like work) get in the way!
As R5oss says, you're a Subaru owner so you're all right!
I can't recall anyone else talking about the oil light coming on at idle after a run with a Subaru diesel...but that actually used to be in the handbooks of cars from the 70's and was OK so long as it went out when the engine was revved again. That was a result of wider tolerances and lesser oil abilities back then. Not sure it applies to any modern engine, let alone a Subaru!
I can make some suggestions further to R5oss:
* I think checking the oil pickup screen (if it exists) is a good idea in this case. I also own a Mazda 2.2l diesel and that is a known issue with those cars- caused by the (very 'clean') oil specification, some oil dilution/injector leak issues and oil change intervals- but by the time the oil light comes on in the Mazda it's too late, the damage has been done.
* Oil light coming on could also be caused by the incorrect oil being used- so it may be a good idea to change the oil and filter and recheck after that.
* With the oil change, it may be wise to send it away for analysis to see what oil was used, whether it was suitable and whether any damage has been done to the engine.
* It will be worth a good scan of the ECU (OBD-II) from a proper scan tool (mechanic-spec I reckon) just to see what codes have been stored in the past, present (they may not have tripped the check engine light) and/or are incipient (have not tripped the check engine light...yet)
* As R5oss said, the engine cut-out on the freeway may or may not be related to the oil light issue. Certainly that type of issue should trip some sort of code or memory store for the ECU...hopefully! This happened to us once on the freeway- the car cut out under acceleration on the freeway on-ramp...luckily it was downhill and it cut back in by itself. Unknown cause at the time but we had turbo hose and other emission control issues and the car was decarbonised by Subaru shortly thereafter...
* ...to that end, if the turbo or intake hoses/pipes are split and/or broken and/or loose it's possible for the car to cut out. May be worth a check esp. as it's relatively easy and simple.
* Given the car didn't restart immediately after cutting out some other things to check are:
- fuel quality
- fuel filter (not clogged and/or full of water)
- fuel pressure, maybe you have a fuel pump/suction control valve problem- I think the OBDII will give you a readout of that (or maybe the commanded value)but it may need a manual (fit a gauge) measurement to see what's really happening
* was the car run out of diesel and it hasn't been primed properly (our had a priming pump in the engine bay mounted to the firewall. If it cuts out it may be worth giving that a go just to see. Check the fuel gauge is calibrated properly- maybe it's indicating lots of fuel but it doesn't really have much.
* was the car stored for a length of time and biology has got into the diesel and therefore the fuel system
* Oil takes a while to drain back into the sump on these cars so let it sit 15 mins before taking the oil reading- this applies when filling it up after an oil change too apparently!
* A clogged DPF will eventually cause the car to cut out but with no DPF light showing you should be OK on that front.
Hope this helps and hope you don't have a more serious issue about to show
Patrick
2010 Forester Diesel (wife's now)
pitrack_1 is offline
  Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Engine and Exhaust > EE20 - 2.0L Diesel
Similar Threads
('06-'08) Oil Consumption Problem Davidms Problems, Maintenance, and Warranty 6 01-03-2019 05:44 AM
Overheating 2008 fxt on hot day up hill moshe_levy Problems, Maintenance, and Warranty 12 05-24-2018 10:58 AM
('09-'13) Engine ran without oil Briceune Problems, Maintenance, and Warranty 3 01-03-2018 03:50 PM
('01-'02) Help! Oil filter threaded inlet broken off at block casting. Solutions? katesubaru EJ25 - 2.5L Non-Turbo (1998-2010) 9 02-12-2016 01:09 PM
