Must Do's for a New Forester? - Subaru Forester Owners Forum
 10Likes
post #1 of 22 (permalink) Old 05-10-2019, 12:49 AM Thread Starter
New User
Car Year: 2018
Car Model: 2018 Forester XT
Hi everyone. I have just got my New Forester XT with Leather trim. Its been in my garage while I fit a few accessories and just wondered what long term Forester owners would or would not do to a new Forester. I have used AutoGlym polish and resin sealer on the paint work and treated the engine to a good coating of Autoglym Vinyl & Rubber care.
What else would others do?
Also I intend to change the engine oil and filter at 1000 miles (old school) and then subsequently every 5000 miles. What would be a good oil change regime for the gearbox and diffs? I do tow a small caravan / trailer quite regularly.
D
ID:	509563   Click image for larger version
Droider is offline
post #2 of 22 (permalink) Old 05-10-2019, 05:52 AM
TMX
Car Year: MY05
Car Model: Forester 2.5 XT
There's a forum called Detailing World in the UK that covers all sorts of paint and wheel sealants. As the car is brand new, I would be tempted to go with a ceramic type sealant for body and wheels and a nano type sealant for the glass.
There's always the option of 3m clear plastic on the panels most likely to see stone chips and road rash.
I couldn't possibly comment on which fluids might be best for the 2019 CVT box. Opie Oils do a decent selection though and bound to have something suitable if you don't want the Subaru own fluid.
How heavy is the trailer/caravan? Anything under 800Kg and I wouldn't worry too much about extra fluid changes, anything above and I would be doing them every 3-4K miles depending on how often you are towing.
If Subaru don't do any decent mats, WeatherTech, based in the US do some decent options and commonly sold in the UK
Droider likes this.
TMX is offline
post #3 of 22 (permalink) Old 05-10-2019, 12:53 PM
Car Model: Forester 2.0XT
Instead of sealant, go for NuFinish. Once a year, and does the same. I went with opticoat and it didn't last long, but other brands may be better, but is pricey.
PPF if you want to protect against rocks.
Mud Flaps.
Droider likes this.
williamn is offline
post #4 of 22 (permalink) Old 05-10-2019, 07:07 PM
StanF's Avatar
Car Model: 2.5i Premium
I changed my diff fluids for the first time at 30k miles and they were very dirty. Next time, I will change them much earlier, like around 15k miles.
StanF
Droider likes this.
StanF is offline
post #5 of 22 (permalink) Old 05-11-2019, 01:44 PM
Car Year: 2018
Car Model: XT Touring
I'm probably older school than you, but I'm curious what you intend to accomplish with those intervals.
My engine is the 2.0T. I'm past the third 6000 mile oil change, and I'd tell you that even at 18,000 miles you'll still see some minor break-in effects. But after seeing the results of the first 6000 miles, there was nothing that made me think I should have changed the oil earlier than 6000.
Results were from Blackstone.
Droider likes this.
Darkseas is offline
post #6 of 22 (permalink) Old 05-11-2019, 02:14 PM
Car Year: 2019
Car Model: Touring
Replace that moped horn !
HeyChris, Droider and supasta like this.
danornan is offline
post #7 of 22 (permalink) Old 05-13-2019, 03:34 AM
New User
CGumina's Avatar
Some advice I can give for caring for the leather: Don't treat it with any "conditioners", or any products that may leave the seats and/or trim glossy or greasy. Modern leathers aren't true "leather", they're basically leather coated vinyl. If you put something on there that leaves a gloss or residue, it actually attracts dirt and debris to stick to it, and can actually abrade the surface and edges prematurely.
If you want to care for it and protect it, clean them often with a very mild cleaner (read: you can use a little bit of hand soap and warm water on a microfiber), and if you want to protect them, Aerospace 303 is perfect for what you need. It won't leave a residue or gloss if buffed off correctly, and will aid in reducing UV damage to the surface over time.
Hope this helps!
Droider likes this.
CGumina is offline
post #8 of 22 (permalink) Old 05-13-2019, 03:46 AM
New User
CGumina's Avatar
Regarding the oil & service intervals: Because you have the turbocharged FA20DIT, which can be quite hard on oil, I think you're damn close to what you asked. I have a 2015 WRX, with the same motor and a 6 speed manual transmission, and even with just daily use and driving around town, 4,000 miles is enough to shear most 5W-30 weight oils down to 5w-20, which is thin for the amount of cylinder pressure these engines build.
My advice: Do your first oil dump at 1,000 miles, and then your next at 4,000 miles, and on the third oil change 4,000 miles later, get a used oil analysis done by Blackstone Laboratories. Here's a good example of what mine looked like previously.
Droider likes this.
CGumina is offline
post #9 of 22 (permalink) Old 05-13-2019, 02:27 PM Thread Starter
New User
Car Year: 2018
Thanks everyone for the input. I have not replied sooner as I had to run North for work and not had chance to reply to you all. But I will.. soooo many questions.
Droider is offline
post #10 of 22 (permalink) Old 05-13-2019, 02:30 PM Thread Starter
New User
Car Year: 2018
PPF?
Droider is offline
post #11 of 22 (permalink) Old 05-13-2019, 02:37 PM Thread Starter
New User
Car Year: 2018
Roger that and thanks for the input. I’d rather do it right rather than skimp.. my VW transporter was on a long life service regime that is totally **** as it cost me a cam rebuild at 220k where if I had changed the oil every 6k I am sure it would still be running fine. Lesson learned.
Droider is offline
post #12 of 22 (permalink) Old 05-15-2019, 03:37 PM
Car Year: 2018
Car Model: 2.5i Premium, manual
Transmission: MT6
D
Consider buying another OME wheel and mounting a full-sized spare. It WILL fit in the tire well but you'll need to modify the flange the retaining bolt slides through--if you don't, the retaining bolt isn't long enough. Once having a full sized spare, you can swap out a flat regardless of where it is (front or back), not having to move the donut spare to the rear. My 2-cents.
randle is offline
post #13 of 22 (permalink) Old 05-16-2019, 08:53 AM
Foz Addict
Sue Brew's Avatar
Car Year: 1118
Car Model: 2.5 Premium& XT tour
Transmission: Quadraphenia Electromatic & the CVT
I applied and then buffed out a coat of Lexol leather preservative on all my leather right after I got my car new... it softened up the leather quite a bit (which, from sitting outside for a while waiting to be sold, and in a closed hot car, likely somewhat "cooked" the leather)… went from stiff and scary to almost leather couch comfy. And don't forget all the other leather "bits" (like the panels on the door and on the center console, etc, as well as the back seat).
I noticed an immediate improvement. Do NOT use something like Armor All (which is really BAD for leather) but something made to nourish and feed leather.
If at first you don't succeed, try, try a bigger hammer.
Sue Brew is offline
post #14 of 22 (permalink) Old 05-16-2019, 09:55 AM
Osceolakidt00!'s Avatar
Car Year: 2019
Car Model: Forester Touring
UK
I regret using the 3m clear plastic on my 2011 Altima. Was allot of money and now looks like a disaster on the car.
The Ocecolakidtoo *
Osceolakidt00! is offline
post #15 of 22 (permalink) Old 05-16-2019, 04:03 PM
Car Year: 2019
Car Model: Touring
I put that on my 2012 motorcycle and it still looks great. I would not hesitate to use it. Key might be in the application.
danornan is offline
  Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Car Care
Similar Threads
Impreza struts vs. Forester struts: The Difference Porter Suspension and Handling 162 12-14-2018 11:28 AM
CLOSED: FS: 2004 Forester XT Full STI Conversion tomenugen Vehicles For Sale 24 10-27-2018 07:53 PM
Subaru Forester License Plate LEDs! See Installed Comparisons! Plug & Play Install! Diode Dynamics Diode Dynamics 141 07-06-2018 06:50 AM
New Forester compared to new Outback cohland Forester Shopping 17 07-18-2015 04:40 PM
Who killed the electric Forester? AmishWarlord General Forum 11 09-26-2006 11:45 AM
