('01-'02) Towing Recommendations - Subaru Forester Owners Forum
 3Likes
  • 1 Post By onave
  • 1 Post By onave
  • 1 Post By SyrForester
post #1 of 15 (permalink) Old 06-14-2019, 11:02 AM Thread Starter
Hi Guys,
I've had my 01 Forster L MT for a few years now and I really don't want to part ways with her. However, I'm starting a party rental business and plan on towing a 4'x6' utility trailer 1-2 days a week within a 25 mile radius. I live in NJ so it's not very hilly but I'm just curious to see what everyone suggests as far as feasibility goes. I understand the tow limits and I don't think I'll ever go over 750lbs (trailer included). I've seen info suggesting an alternate transmission cooler, is this worth it for my scenario? If I get 2 years out of it, I'd be happy. Otherwise I may just trade the car in for a truck which I'd really hate to do but I don't want to kill the car.
Thanks in advance!
1roamingnome likes this.
onave is offline
post #2 of 15 (permalink) Old 06-14-2019, 11:05 AM Thread Starter
Also forgot to mention that the car has a relatively new clutch, new head gaskets and a little over 142k miles
onave is offline
post #3 of 15 (permalink) Old 06-14-2019, 05:06 PM
You're towing with a MT and not an AT. Transmission coolers are for AT only. MT gear oil never gets hot. Your clutch will wear faster than normal due to the need to slip to get the rig moving. Towing with AT is easier, AT fluid needs to be changed more often due to heat generated. There are those that will argue MT is better for towing. I disagree, I towed a 3300lbs trailer from Philadelphia to Austin, TX. My Subaru now has 215,000 miles and the transmission and engine are just fine.
Sent from my Pixel XL using Tapatalk
bman400 is offline
post #4 of 15 (permalink) Old 06-15-2019, 07:16 AM Thread Starter
Thanks for the input. You pulled 3k in a forester? That's crazy man. I think at most I'll be towing 900lbs. Hopefully I can get a few more years out of it.
Do you have any suggestions for preventing clutch wear? Other than driving it the way it should be driven lol. Just wanna cover my bases here.
onave is offline
post #5 of 15 (permalink) Old 06-15-2019, 09:54 AM
Start slow. Release clutch as quickly as possible, the less slipping the less wear. In other words don't force your acceleration. Once you're moving the clutch does not need slipping for subsequent gear changes.
bman400 is offline
post #6 of 15 (permalink) Old 06-16-2019, 05:40 AM Thread Starter
Thanks man! Just installed the hitch yesterday so I'll let you know how everything goes. Really appreciate the advice. Fingers crossed for my clutch/trans lol
onave is offline
post #7 of 15 (permalink) Old 06-18-2019, 04:51 PM
SyrForester's Avatar
Car Year: 2018
You won't need a transmission cooler with a manual, so that's good.
Second the advice for not giving it to much gas when taking off. you don't want to burn the clutch.
2018 Forester 2.5i 6MT
20mm RSB, Hitch
SyrForester is offline
post #8 of 15 (permalink) Old 06-18-2019, 06:10 PM
under heavy duty actions ,yes mt gearbox oil does get hot, but to move it to and from to a cooler,you would need to install drains, lines a pump and cooler, and often a thermal valve inline, not worth that for what you will do,................. BUT an engine oil cooler external to the radiator will help your stressed engine quite bit................, under towing hard conditions, it is possible for oil to go well over 240 or more degrees,over 300 D can become a problem, , install a oil filter adapter and lines to a 2 to 4 row cooler in front of the radiator......... keep the oil temp down to about 180 to 210 or so,
leland grant is offline
post #9 of 15 (permalink) Old 06-19-2019, 04:36 AM
Overkill for the OP towing requirement. He is towing less than 1000 lbs. He can also run 5w-40, or 15w-50 oil as recommended in the owner's manual.
bman400 is offline
post #10 of 15 (permalink) Old 06-19-2019, 12:02 PM
heavier weight oil can help. but high temps still cause problems,................ i know what i have done for myself on work vehicles and others cars. .............. on my last work car with 500 stops over 55 miles i used a 3 row cooler for atf, and a smaller one for oil,................ rotella t6 5w40 and a napa gold filter . changed every 3500 miles ................... oil temp settled at 200 D[measured at the oil filter with my 900D max laser guided heat gun] and idle psi at 40 and 2000 rpm at 60 psi, ............ overkill in your opinion , which is not wrong generally in this matter, ,,,,,,,,,,, but it is his car . and he asked for advice based on our experiences ............., and that is my experience and advice, you either do the most you can to protector your large investment or you dont, and you live with the results
post #11 of 15 (permalink) Old 06-25-2019, 06:09 AM
Car Year: 2018
I've towed more than twice what he is planning on towing with my 2018 2.5i and have never got the oil above 220F.
bman400 likes this.
20mm RSB, Hitch
post #12 of 15 (permalink) Old 06-25-2019, 07:21 AM
I would agree. @leland grant has posted very extreme towing case, but he also has not provided any specifics either. Such as trailer weight, ambient temperature etc....I am not certain 100% that he is even talking about using a Subaru Forester for towing either, as he mentions "work vehicles".
bman400 is offline
post #13 of 15 (permalink) Old 06-25-2019, 07:54 AM
CCRIEN's Avatar
Car Model: Forester AW
Transmission: Manual with low ratio
If you do find yourself pulling away on a steep incline, ramp etc, then you can always slip it into ( manual) low ratio to pull away in first with negligible strain and wear on the clutch, then go back into std/ high ratio when you're up and away moving, like when you're up into second or third gear. Low ratio first and second are also useful in really slow moving traffic jams when towing, I find, saves keep dipping and slipping the clutch.
2003 Forester AW, 2005 Impreza GX
CCRIEN is offline
post #14 of 15 (permalink) Old 06-25-2019, 08:10 AM
OP is in New Jersey USA. I am not sure if the US version has the ability to switch to lo from hi like the European model.
bman400 is offline
post #15 of 15 (permalink) Old 06-25-2019, 09:12 AM
CCRIEN's Avatar
Learn something every day thanks! But that would be a pity, it's ( low ratio) great for towing, not just off road.
CCRIEN is offline
