('19+) DrawTite Hitch installed on 2019 Touring - Subaru Forester Owners Forum
 2Likes
  • 2 Post By cowdog360
post #1 of 13 (permalink) Old 05-06-2019, 01:47 PM Thread Starter
Hello everyone, I installed the Draw-Tite hitch purchased from eTrailers last weekend. Overall, it wasn't too bad of an install, took a few hours with some assistance. I went with it because of the lower cost as well as easier installation.
I also installed the wiring harness, ran it through one of the grommets in the spare tire well, and dressed it up with some 3/8" corrugated tubing.
My impression is the kit is overall pretty good. One gripe I had is that the end piece on the receiver is welded slightly crooked, and the bolt holes weren't exactly perfect for getting the M6 bolts back in on the driver's side.
Here are some pictures of what the install looks like.
ID:	509349   Click image for larger version
ID:	509351   Click image for larger version
Even_Stephen and thatguy2 like this.
cowdog360 is offline
post #2 of 13 (permalink) Old 05-07-2019, 10:27 AM
coregrind's Avatar
Car Year: 2019
Car Model: Forester Premium
I bought my Draw-Tite from etrailer.com. Mine appeared to be fully in alignment during installation. I did notice a couple of chips and scuffs in the paint, most likely due to shipping, but they're not visible after the install. Overall, I'm really happy with the hitch and the cost.
- Chris
coregrind is online now
post #3 of 13 (permalink) Old 05-08-2019, 04:18 PM
Car Model: Forester 2.5i Tour
i read a lot of comments online about mixing diesel fuel/used engine oil together and 'paint' the hitch every year to keep rust at away..
Brian
thatguy2 is offline
post #4 of 13 (permalink) Old 05-08-2019, 04:28 PM
coregrind's Avatar
Car Year: 2019
@thatguy2
That suggestion is a new one for me. I don't have much use for diesel otherwise so I'm not likely to try it myself. All I've ever used is CRC Rubberized Undercoating, available in a spray can. Typically I just apply it where needed, when the original paint gets blasted enough from debris.
- Chris
post #5 of 13 (permalink) Old 05-08-2019, 04:46 PM
Car Model: Forester XT Sport
1 1/4 or 2"
looks big. 2"?
frijoles is offline
post #6 of 13 (permalink) Old 05-09-2019, 08:03 PM
PearlWhite's Avatar
Brian
Or instead of killing the planet you could use wax based chain bar oil.
PearlWhite is offline
post #7 of 13 (permalink) Old 05-18-2019, 02:38 AM
Car Year: 2019
I’ve installed the same hitch on my 19 Premium.
I had the Curt hitch on my 13 XV and it worked really well The DrawTite hitch for the Forester was a bit less expensive from eTrailer and the j-pin compatibility was a must. We use a cargo carrier that rattles and moves around, so I was looking to improve that.
The hitch arrived really banged up from shipping. eTrailer sent a replacement out next-day.
Install took 3 hours. No issues. Wiring harness was a simple addition. I’m yet to use the hitch, but I expect no issues.
My only complaint: the receiver is open on the back. I opted to put a protective rubber cover over the opening on the back, but being open though-and-through causes the cover to just collect the road debris inside the receiver opening.
supasta is offline
post #8 of 13 (permalink) Old 05-24-2019, 07:51 AM
Car Year: 2019
Car Model: Forester Convenience
Any suggestions on which to purchase either the DrawTite or Curt hitch from online in Canada with reasonable shipping fees? (also for 2019)
Plsavaria is offline
post #9 of 13 (permalink) Old 05-24-2019, 08:32 AM
coregrind's Avatar
Car Year: 2019
For the 2019, I feel the Draw-Tite has an easier install procedure since no modification to holes in the body are required; the Curt requires 2 holes be slotted. It looks like etrailer.com ships to Canada so it might be worth checking them out.
- Chris
post #10 of 13 (permalink) Old 05-24-2019, 09:18 AM
Car Year: 2018
Car Model: LTD w/eyesight
Do what I did.
Order from etrailer.com in the US.
They will free ship to one of the border parcel services in Pembina ND.
Make the short trip to the border and save yourself a lot of money on shipping.
Because the hitch only sells for just over $100 US, Canada Customs will most likely wave you right through with no taxes payable.
bigbird1 is offline
post #11 of 13 (permalink) Old 05-24-2019, 09:31 AM
JamesBond's Avatar
Car Year: 2018
Car Model: Outback 3.6 Limited
The rear-end of the black Touring actually looks half way decent. That's probably why I'm drawn to the Sport trim. The band between the tail lights is blacked out.
JamesBond is offline
post #12 of 13 (permalink) Old 05-24-2019, 10:30 AM
coregrind's Avatar
Car Year: 2019
Vinyl wrap in black can easily be applied in this area to any trim level if that's your desired effect on a different body color.
- Chris
post #13 of 13 (permalink) Old 05-26-2019, 05:38 AM
MassSubie's Avatar
Car Year: 2019
Car Model: Forester - Touring
I had some concerns about potential warranty issues, but in the end wound up going with the Draw-tite Class III hitch sourced from eTrailers.com as well. A local shop mounted it for me, so no experience there. I am only planning to use it for a bike rack and to lower risks of a warranty claim issue on any possible powertrain problem later, I didn't get the wiring harness. It looks okay, and so far it's been pretty uneventful in bike hauling, which I suppose is a good thing - the hitch that you don't think about is a good hitch, I suppose.
MassSubie is offline
Similar Threads
2019 Forester Touring observations, critique, questions Osceolakidt00! Forester Shopping 14 06-11-2019 08:24 AM
('06-'08) Bobby's WRB '07 FSXT 2.5x_sleeper Members' Journals 1761 03-29-2019 04:41 PM
2019 Touring Color Combo? EnvoyEd03 Forester Shopping 9 12-27-2018 08:35 PM
Sirwilliam's "blue Wasabi" sirwilliam Members' Journals 538 11-07-2014 12:36 AM
Will a trailer hitch fit with Cobb cat-back installed? toddlamp Towing and Hauling 7 11-07-2006 11:45 AM
