Method Rally Wheels (limited stock - Pre-order now!) - Page 13 - Subaru Forester Owners Forum
 48Likes
post #181 of 218 (permalink) Old 02-07-2018, 02:16 PM
Luis Franco's Avatar
Car Model: Subaru Forester XS
Originally Posted by Discount Tire View Post
Thank you for your question. The Method wheels come in 15,17 and 18 inch sizing. Please let us know if we can send you a quote.
Yes, the 15's in Black, for a 17 NA Forester, with BFG KO2's in 235/75/R15, to TX 78045
Luis Franco is offline
post #182 of 218 (permalink) Old 02-08-2018, 07:03 AM Thread Starter
Supporting Vendor
Discount Tire's Avatar
Car Model: All
PM coming your way.
Low Prices! More Choices! Trusted Experts!
Discount Tire is offline
post #183 of 218 (permalink) Old 02-27-2018, 07:42 PM
Car Year: 2018
Car Model: XT Touring
When will you have the 503's in stock? I am interested in them with the terrain contacts in 225/60/17
Rudacris is offline
post #184 of 218 (permalink) Old 02-28-2018, 08:30 AM Thread Starter
Supporting Vendor
Car Model: All
Method Wheels has some in stock.
Pm coming your way.
post #185 of 218 (permalink) Old 03-04-2018, 08:36 PM
Car Model: forester x touring
Just want to verify these wheels will fit a 2011 Forester x touring. Planning on 235/75/15 Falken At.
regdog77 is offline
post #186 of 218 (permalink) Old 03-05-2018, 08:38 AM Thread Starter
Supporting Vendor
Car Model: All
The wheel fitment is good to go, but as we noted in our PM reply, the tires are aggressive and modifications will be needed to make them fit .
post #187 of 218 (permalink) Old 04-15-2018, 01:16 PM
Itanius's Avatar
Car Year: 2018
Hello! Could I get a quote on MR502 17x8 Bronze with BFG KO2 in 225/65-17, with TPMS. Set of FIVE to 97116. Thanks!
Itanius is offline
post #188 of 218 (permalink) Old 04-16-2018, 08:26 AM Thread Starter
Supporting Vendor
Car Model: All
Most definitely - PM coming your way!
post #189 of 218 (permalink) Old 06-02-2018, 02:37 PM
Car Model: Forester X
Will these 15" 502s with some 225/70/15 Geolanders clear my 2011 Forester X with stock suspension?
istone is offline
post #190 of 218 (permalink) Old 06-04-2018, 07:22 AM Thread Starter
Supporting Vendor
Car Model: All
They sure will
post #191 of 218 (permalink) Old 06-05-2018, 12:17 PM
Womprat57's Avatar
Car Model: Forester XS
Big shout out to Matt at Discount Tire Direct!! My 225-70-15 Yokohama Geolander A/t G015's and Method 502 VT-Spec wheels and lugs came in today!
I think I gained about an inch of lift at least. Still looking for my torque wrench before I take them for a spin but first impressions are fantastic, totally transforms the car.
DTD was awesome, thank you so very much!
ID:	489287   Click image for larger version
Womprat57 is offline
post #192 of 218 (permalink) Old 06-05-2018, 02:43 PM Thread Starter
Supporting Vendor
Car Model: All
Very nice!!! Thank you for sharing and for giving us the opportunity to help!
post #193 of 218 (permalink) Old 06-26-2018, 11:46 PM
cmpxchg's Avatar
Car Model: Forester 2.5i
Thanks a ton to you guys for sharing information and experience. I jumped on memorial day deal from Discount Tire Direct for Method 502 VT-Spec with P235/75/15 Yokohama Geolandar G015. I chose G015 for comfort on paved road. Turns out they are quieter and smoother than outgoing Pirelli Cinturato all-season. Maybe less-rim-more-tire played a role there too.
Below I listed my method for installing Method 502 VT-spec wheels with oversize tires.
1) Clearance
I installed 1" lift spacers on front and rear shocks for wheel / ground clearance. I think 1" lift is the minimum if you decide to go with 235/75r15. Unintended consequence of lift is my rear camber actually got better.
2) Rubbing avoidance
For potential rubbing, I pushed out fender liners with heat gun and hammer. Low offset of the wheel (+15mm) helps a lot, but if you don't modify liner, there will be some rubbing at front wheel when turning.
3) TPMS
My research on Forester TPMS wasn't completed so I ordered wheel/tire mounted and balanced san TPMS.
Glad that I skipped TPMS when I ordered as it turned out TPMS is major headache for Subarus when you swap out wheels.
I concluded that the most reasonable solution is to clone the sensors so that you don't have to go to dealer to have the system 'relearn' the new IDs every time you swap out wheels.
I went with Autel MX 315MHz sensors with metal stem ($25 each eBay/amazon). I also purchased Autel TPMS tool TS408 ($112 eBay) for cloning. (Cheaper Autel tool exists (called MaxiPAD $50 off ebay), but there are some unconfirmed reports that it can't read OEM Subaru sensors inside wheel).
I installed these sensors myself after local tire shops quoted $86 + tax for just installation/rebalancing. I also didn't want to haul the tires all the way to the shop and back. DIY TPMS installation involved breaking bead only on TPMS side, removing old valve stem, sliding/screwing in new sensor, reseating tire, and rebalancing.
For rebalance, I measured weight difference between old rubber stem and new Autel MX TPMS sensors. The difference was 0.77 oz, which is basically three 1/4 oz balance weight. Using some arithmetic and basic trigonometry, I moved around a few weights to compensate the 0.77 oz difference. I ended up using net zero weight for all four wheels.
The most difficult part of DIY TPMS installation was seating the tire. The rim has very tight space inside, so the installed TPMS module prevents the bead of tire ever so slightly from touching the seat of the rim. I solved this problem by using L-shaped paintless dent-removal hook to get the bead over the TPMS making initial seal. Because of this I spent about an hour for the first wheel. But once I learned the trick, it took 10 minutes each for the rests.
If I had known all these, I would have asked Discount Tires about these MX sensors when I ordered wheel/tire set.
4) Wheel center cap
I've been reading that these racing wheels don't have ridge for center caps, so you have to fashion some kind of adapter to put center cap in place.
But upon receiving the wheels, I noticed that there is clearly a ring intended for center cap. I don't know if the design has changed, but the stock 60mm diameter Subaru plastic center cap goes straight in and secures perfectly.
So I bought and installed black 60mm center caps with Subaru logo from eBay (~$15).
ID:	490327   Click image for larger version
ID:	490329   Click image for larger version
ID:	490331   Click image for larger version
ID:	490333   Click image for larger version
cmpxchg is offline
post #194 of 218 (permalink) Old 06-27-2018, 07:51 AM Thread Starter
Supporting Vendor
Car Model: All
cmpxchg, thank you for the very detailed report of installing your new Yokohama Geolandar G015 tires with Method 502 VT-Spec wheels. Great job explaining your process along with photos.
Thank you for your business.
post #195 of 218 (permalink) Old 10-28-2018, 07:01 AM
bvalks's Avatar
Car Model: 2.5XT
Do you guys ship to Canada?
bvalks is offline
  Subaru Forester Owners Forum > Vendor Member Section > Discount Tire
