Forester Maintenance Parts Thread - Subaru Forester Owners Forum
 5Likes
post #1 of 246 (permalink) Old 11-02-2010, 08:36 AM Thread Starter
Supporting Vendor
SubaruPartsGirl's Avatar
Car Model: Outback 3.6R Limited
Transmission: High Torque CVT
Feedback Score: 29 reviews
Here is a list of maintenance parts to keep your Forester in top shape! If you have any questions or would like me to add something else to this thread please feel free to post!
11/30/2018 - Updated!!!
Filters
Oil Filter - 15208AA12A - $5.12/ea (EJ Series)
Oil Filter - 15208AA130 - $6.04/ea (FB Series)
Oil Filter - 15208AA15A - $5.15/ea (FB Series)
Oil Filter - 15208AA170 - $6.04/ea (FA Series)
Crush Washers - 803916010 - $1.08/ea
Crush Washers - 11126AA000 - $.96/ea
Subaru 0W20 Synthetic - SOA427V1310 - $6.87/QT x 6
Air Filters
Short - 16546AA020 - $12.27
Long - 16546AA07A - $12.27
Square - 16546AA10A - $18.42
Square - 16546AA12A - $16.88
*Need to know which one you take, just ask!
Fuel Filters - 42072PA010 - $28.42
*Fits up to 2004, in tank filters extra!
PCV Valves
We recommend replacing your PCV (Pressure Control Valve) about once every 30k. Not sure if your valve needs replacing? If you pull it out and shake it you should hear the ball valve knocking back and forth. If you don't hear it banging around then you know it's gummed up!
1998-2002 - 11810AA000 - $8.85
2002-2008 N/A - 11810AA040 - $13.04
2004-2008 Turbo - 11819AA001 - $7.32 (w/plastic connector)
2009-4/2/2009 Turbo - 11810AA040 - $13.04
2009-2010 N/A - 11810AA100 - $15.35
04/2/2009 - 2013 Turbo - 11810AA120 - $11.50
2011-2016 25B N/A - 11810AA131 - $15.35
2014-2016 20F Turbo - 11810AA141 - $15.35
Fluids
Check your "Warranty & Maintenance" booklet in your owner's information packet for your vehicle's maintenance intervals. We recommend changing your coolant along with the coolant conditioner every 30k for long life coolant users, Super coolant is good up to 107,500mi or 11 years!
Brake fluid should be refreshed or replaced every 30k unless you live in a very humid climate or at high altitude.
Complete your AWD Service with Subaru crush washers and gaskets, ask Jackie for details!
Coolant, Long Life - SOA868V9210 - $24.60/gal
*For vehicles up to 2009, non mixed.
Coolant, Super - SOA868V9270 - $22.04/gal
*For vehicles 2009+, pre-mixed.
Coolant Conditioner - SOA635071 - $1.77
Brake Fluid - SOA868V9221 - $5.64/pint
ATF/PS HP Fluid - SOA427V1500 - $6.49/qt
*For vehicles 2006 and up.
Subaru HP Gear Oil, 75W90 - SOA427V1700 - $9.69/qt
Subaru LSD Oil, 80W90 - $9.50/qt
Additives
Over time your heating and cooling system can get develop odors that are unpleasant. Use an A/C refresher kit to clean out the ducts and breathe easy! Think of it like a "Draino" for your duct system, it foams up and runs out cleaning the walls of the ducts and removing odors in the system. Try this kit along with a new pollen filter!
A/C Refresher Kit - SOA868V9315 - $14.29
*Includes evaporator foam, intake spray and tube for use.
Subaru offers an engine maintenance kit to keep your Subaru in top shape. Is your throttle response a little sluggish? Reduced gas mileage? Your engine works more efficiently when it's moving parts are moving free and easy!
Subaru Engine Maintenance Kit - $Temporarily On Hold
*Includes top engine clean (tool required), throttle clean and fuel additive.
Spark Plugs, Ignition Wires, Coil Packs, Knock Sensors
1998 Platinum Plugs - 22401AA570 - $10.19/ea x 4
1999-2004 Copper Plugs - 22401AA310 - $2.27/ea x 4
2005-2010 N/A Platinum Plugs - 22401AA65A - $9.19/ea x 4
2004-2008 Turbo Iridium Plugs - 22401AA630 - $12.27 x 4
2011-2016 25B N/A Plugs - 22401AA781 - $16.12 x 4
2009-2013 Turbo Iridium Plugs - 22401AA670 - $12.27 x 4
2014-2016 Turbo Iridium Plugs - 22401AA830 - $19.19 X 4
1998 Ignition Wire Set - SOA430Q121 - $49.96
1999-2004 N/A Ignition Wire Set - SOA430Q119 - $43.04
2005-2008 N/A Ignition Wire Set - SOA430Q124 - $48.42
2004-2008 Turbo Individual Coil Packs - 22433AA542 - $84.58/ea
1998 Coil Pack - 22433AA370 - $102.55
1999-2004 N/A Coil Pack - 22433AA570 - $152.27
2005 - 2008 N/A Coil Pack - 22433AA580 - $126.88
1998 Knock Sensor - 22060AA061 - $92.27
1999-2002 Knock Sensor - 22060AA070 - $99.96
2003-2004 N/A Knock Sensor - 22060AA100 - $96.12
2004-2005 Turbo Knock Sensor - 22060AA111 - $96.12
2006-2008 Knock Sensor - 22060AA140 - $96.12
Drive Belts
Inspect your drive belts regularly for cracks and signs of wear or fraying. A broken drive belt can easily take out associated parts in it's path. Subaru recommends inspecting your drive belts every 30k and replacing at 105k however we often find the need to replace them around 60k-70k.
1998-2006 A/C Belt - 73323AC000 - $13.81
11/2007 - 2008 A/C Belt - 73323SA000 - $26.88
1998-2002 Alternator Belt - 809218270 - $14.58
2003-2005 Alternator Belt - 809218450 - $17.65
2006 Alternator Belt - 809218370 - $14.58
2007-2008 N/A Alternator Belt - 809218370 - $14.58
2007-2008 Turbo Alternator Belt - 809218450 - $17.65
Stretch Belt Set - 11718AA082 - $63.81
*Sold with tool kit.
Cabin Filters
1998-2000 Filter Kit - G3210FC000 - $29.17
1998-2000 Filter Cover - G3210FC010 - $20.79
*Sorry, these cover kits are now discontinued, filter is still available!!!
2001-2002 Filter Kit - G3210FC200 - $33.29
2003-2008 Filter Kit - 72880SA000 - $34.45
2009+ Cabin Filter - 72880FG000 - $17.68
Remanufactured Parts - Non-Turbo Only!
1998-2000 Front Axle Shaft - SOA966H900R1 - $147.65 + $40.00 CORE
2001-2002 Front Axle Shaft - SOA966H1100R1 - $147.65 + $40.00 CORE
2003-2006 Front Axle Shaft - SOA966H1200R1 - $147.65 + $40.00 CORE
2009-2013 Front Axle Shaft - SOA966H1500R1 - $157.65 + $40.00 CORE
5/97-2/02 M/T Starter - 23300AA380R1 - $159.96 + $50.00 CORE
5-97-2/02 A/T Starter - 23300AA390R1 - $161.50 + $50.00 CORE
1998 Alternator - 23700AA290R1 - $234.58 + $50.00 CORE
7/98-2/02 Alternator - 23700AA390R1 - $234.58 + $50.00 CORE
Note: When selling remanufactured parts we must collect a core charge for the item unless you present the old unit at the time of sale. When shipping remanufactured parts we will quote you for shipping both to and from your house and include a label to return the core back to us. Cores must be returned to us in the box supplied with the part. Core refunds will be given in the original form of payment.
Wheel Bearings
1998-2002 Front Wheel Bearing Kit - $83.48
*Includes bearing, two seals and axle nut.
-28016AA011NT - $63.04 x 1
-28015AA070 - $7.83 x 1
-28015AA080 - $8.51 x 1
-28044AA001 - $4.10 x 1
1998-2002 Rear Wheel Bearing Kit - $92.95
*Includes bearing, three seals and axle nut.
-28016AA030 - $63.04 x 1
-28015AA090 - $8.31 x 1
-28015AA100 - $8.31 x 1
-28015AA110 - $9.19 x 1
2003-2008 Front Wheel Bearing Kit - $85.31
-28316FE000 - $65.19 x 1
-902170049 - $3.78 x 1
2003-2008 Rear Wheel Bearing Kit - $92.95
-902170049 - $4.10 x 1
Disclaimer: Although every effort has been made to avoid errors on the parts listed above, our part catalogs are not perfect and neither am I! To make sure that we get the right parts for you it is always best to supply a VIN so that we can double check fitment before sending your order. You know the saying..."Do it right, or do it twice!"
Thanks,
Jackie
Natedog and AlcyoneSpiral like this.
SubaruPartsGirl is offline
post #2 of 246 (permalink) Old 02-15-2012, 08:53 AM Thread Starter
Supporting Vendor
Updated prices!!!!
post #3 of 246 (permalink) Old 03-03-2012, 02:31 PM
Car Model: Forester XT Ltd Tech
What's included in the G3010SA100 cabin air "kit"? Also, do you ship to Canada?
Canadian_XT is offline
post #4 of 246 (permalink) Old 03-05-2012, 04:49 AM Thread Starter
Supporting Vendor
It lists it as a kit but really it's just a filter. We certainly ship to Canada using USPS.
Thanks,
Jackie
Annapolis Suby
443-837-1422
post #5 of 246 (permalink) Old 04-27-2012, 05:00 AM Thread Starter
Supporting Vendor
Updated again!
post #6 of 246 (permalink) Old 05-05-2012, 05:38 PM
Car Year: 06
Car Model: XTL
Hi there, 1st post here, do you ship to Australia?
dayak is offline
post #7 of 246 (permalink) Old 05-07-2012, 05:09 AM Thread Starter
Supporting Vendor
As long as it can be sent via USPS Priority Mail, absolutely! There are some size limitations and weight limitations for what I can send and how but generally we can squeeze a lot of things in flat rate boxes to make it worthwhile.
Can I get you a quote for something you are interested in?
post #8 of 246 (permalink) Old 05-08-2012, 07:31 PM
cutter44's Avatar
Hi Jackie,
Don't know if this is the preferred way to ask for a quote or if you'd rather an off-forum email, but here goes. I'd like a quote (with shipping to ZIP 02364) for a pair of "link assembly-front stabilizer", part number 20470SA000. Left and right seem to have the same part number, and I'd need both. And I've also seen references to there being a superceded part number for them: 20470SA001. Do they come with the required bolts for attaching? I replaced the rears a year or so ago, and I think I can probably tackle the fronts as well.
As noted in my sig, I have a 2006 LL Bean Edition Forester. If you need the VIN, let me know.
Thanks.
2006 Forester 2.5 X
L.L. Bean Edition
Regal Blue Pearl/SGM
cutter44 is offline
post #9 of 246 (permalink) Old 05-09-2012, 04:30 AM Thread Starter
Supporting Vendor
You are correct, the original part number has superceeded to the number you supplied. the nuts are not included but we certainly stock them as well as the links.
Link - 20470SA001 - $25.28/ea
Nut - 902350001 - $1.27 x 4
Thanks,
Jackie
post #10 of 246 (permalink) Old 05-09-2012, 06:02 AM
cutter44's Avatar
Thanks for the reply, Jackie. And shipping cost to 02364? I'm guessing those prices don't include shipping. Finally, is a phone call the best way to order from you? Thanks.
2006 Forester 2.5 X
L.L. Bean Edition
cutter44 is offline
post #11 of 246 (permalink) Old 05-09-2012, 06:33 AM Thread Starter
Supporting Vendor
I can ship it for $6.00 via USPS Priority Mail. You can certainly give me a ring with a credit card number or I can send over a PayPal invoice for you. We accept pretty much all forms of payment...cash, check, money order, credit cards, PayPal and Subaru Bucks.
Thanks,
Jackie
post #12 of 246 (permalink) Old 05-09-2012, 07:37 AM
cutter44's Avatar
Perfect. I'll send you a PM with email info for a Paypal Invoice. Thanks.
2006 Forester 2.5 X
L.L. Bean Edition
cutter44 is offline
post #13 of 246 (permalink) Old 05-09-2012, 10:07 AM Thread Starter
Supporting Vendor
Great, I will send it over shortly! Thanks!
post #14 of 246 (permalink) Old 08-26-2012, 12:11 PM
MudRunner's Avatar
Car Model: V50 T5
Transmission: 6spd Manual
Hey Jackie... Part# for the OEM 4EAT Trans filter?
Working on the parts list for my Outback.
-Zach
MY'06 Volvo V50 T5 6MT SportWagon
I miss my Subaru.
MudRunner is offline
post #15 of 246 (permalink) Old 09-27-2012, 06:53 AM Thread Starter
Supporting Vendor
Sure, here is the number for you...
ATF Filter - 38325AA032 - $26.75
Thanks,
Jackie
  Subaru Forester Owners Forum > Vendors > Annapolis Subaru
