There appears to be 2 oil filters for Subaru in general, one slightly smaller (for Turbo?), and one larger. Thanks to wixfilters.com(which has a little more detailed spec available online), I spent some time digging for info, and found that physically they should fit either way, but the smaller version (51365) has SIGNIFICANTLY better specs than the other (Wix part 51365 and 51334).
Aside from the physical/size difference:
Wix 51365 Wix 51334
Beta Ratio 2/20=15/22 2/20=22/40
Burst Pressure-PSI 300 280
All other specs are exactly the same.
Here's the kicker, Wix51365 is fit as the transmission spin-on filter. I have posted a thread on the old site regarding subie/non-subie ATF filters and found that subie version has a cylinder screen/mesh that covers the bypass (no true bypass) comparing to the non-subie version.
I'll start using 51365 all around once my filter reserve is exhausted, maybe once or twice yearly for the tranny, and reasonable OCI for the engine.
Comments? (BTW, my Forester is out of warranty).
Wix 51365 Wix 51334
