Riff, Be careful about installing an inline filter on your trans cooler line,I have never seen it done. Unless someone makes an inline auto
trans filter to handle the flow and temp , I would stay away from it. Also your trans is equipped
with an oem filter already.
ShhhhI will try and stay as straight forward as possible about
installing an accessory trans cooler in your Suby. First off I would find
the atf outlet line on your trans. You will want to cut into that line and
attach it to the inlet or intake port of your new cooler. Then from the other port on the new cooler,the line should run into the atf radiator
port and that should do it for the hook up. For a street application you always want the atf fluid to be warmed by the engine coolant,so your trans has warm fluid to work with. If you plum it the other way your atf temp will vary with the outside temperature.
Let me know if I helped or confused you . ed
