NO NO NO NO NO!!!!I ordered some wrinkle paint to paint up some stuff under the hood. I was thinking of painting the tmic including the fins. Would this cause problems?
Yeah, the end tanks should be fine with wrinkle finish, but for the fins, keep it to normal engine block paint, and a thin coat at that.The endtanks should be ok right?
Correct, but leave the cooling fins naked. :wink:The endtanks should be ok right?
No problem, but you already knew the answer & you were testing us! :wink:Thanks guys.
