Emeritus Forum Staff
Should do... Looks exactly like the one I fitted
I should say so... you'll need new bushes for the mounts due to the thicker bar. Also you might as well fit new drop links at the same time - in my case I had to as the bolts were rusted tight and I ended up having to take a hacksaw to them!
2017 SJ XT
Last time I did this (had a 22mm rear arb on but took it off to downgrade for my Dad who had my car for a year) I had to do exactly the same thing as the nuts had rusted on. A mechanic friend of mine says he always takes the angle grinder to them straight away to avoid messing about! And yes, have found some poly bushes to go with it. Did you go Whiteline for the drop links?
I went with standard Subaru drop links in the end - I figured if they go, I can just replace them (for the price of the Whitelines, you can get at least a couple of sets) and the Subaru ones are pretty good I'm told.
I've got the stock mounts on too but I hear that these can be a bit fragile so as funds / time permit, I may swap these for chunkier items.
