I've googled, I swear. I've found '07 WRX schematics, I've found 2005 Forester schematics. But I haven't been able to find '07 schematics.
I'm wondering if I can retrofit the 2005 clock to the 2007 harness AND run a pair of LEDs tapped to the '07 harness to indicate whether the passenger bag is on or off. I suspect that the logic to determine whether the bag is on or off is in the clock (similar to the WRX) which would defeat my plan. But if the logic is done elsewhere and all the clock contains is a pair of LEDs that are powered on or off, then I can surface mount two external LEDs somewhere, tap them into the '07 harness, and use a sticky-backed label to show that one is for "Passenger Airbag ON" and "Passenger Airbag OFF."
Does anyone have a diagram? Feedback on what I'm describing?
Thank you.
Thank you.
