1 - 14 of 14 Posts
2015 Highlander AWD XLE 6AT
Subaru's recommended cold tire pressures for the '09 Forester are:
225/55R17: 32F / 30R
215/65R16: 30F / 29R​
I have my 215/65R16 winter tires set at 32F / 31R... they seem to be working out rather well so far.
HTH,
Jim / crewzer
2000 Forester
I'm assuming you know that the term "cold" doesn't refer to cold weather, rather just standing tire pressure, before extended driving. No offence intended, just didn't want people to get confused!
2001 Forester
Interesting points on tire pressure...it seems each has their own preference.
I have a question: Is the pressures listed in the drivers door jam recommended for the stock tires or for all tires you put on the car? The reason I ask is because tires can be so different, it would seem reasonable that different tires would perform better at different pressures. Anyone know for sure?:icon_question:
2007 SG9 Forester XT Stick Shift
I run my winter tires at 37-38 PSI. Anything lower and I found the handling a bit handful. I am running 215/65R16 Gislaved Nordfrost 5 winter tires. The 65 aspect ratio might have something to do with it.
The pressures listed on the B-pillar placard are Subaru's recommendations for the specific tires and conditions listed on the placard. Changing tires and/or conditions may require different pressures.
For example, my car's placard lists the pressure specs for the 225/55R17 tires which were supplied with the car and its trim level. The owner's manual contains the same info, and it also contains different (lower) pressure specs for the 215/65R16 tires fitted to the base model.
You may find this Tire Rack link to be informative.
HTH,
Jim / crewzer
1 - 14 of 14 Posts
