1 - 7 of 7 Posts
2002 forrester l
i am having a problem with the front windshield squirter not squirting.
wipers wipe but no squirt.schematic shows wipers and squirter share same fuse.
back one works. have no voltage at motor connector.:confused:
fluid's good? might just be clogged. check the squirter heads. if they look clear, check the lines under the hood and make sure there's flow coming through and no broken lines.
oh didn't see the voltage at motor part lol!
i've got to ask this though.. it was working before right? because iirc, the SF foresters have that stalk where you have to push the button on the end of the stalk to activate the squirters and pull the stalk to activate the wipers..
i know of some bugeye guys who thought theirs were broken, but it turns out they didn't know that the functions were separate.
hmm otherwise i duno. :\ i mean you've checked the bottle's plugs and stuff right? the pump is separate for front and rear... if you provide DC, does the motor operate?
checked?
worse comes to worst.. the pump is cheap to replace.
1 - 7 of 7 Posts
