1 - 10 of 10 Posts
MY11 WRX STi Sedan 6MT
Will probably fit as it's the "complete" package, however yours may only have one cat?? (Database not very clear).
Should have photographed the rest of the exhaust system whilst you were doing the back box. :biggrin::biggrin::biggrin:
Edit:
just realised.......:crazy:
51 plate will be newage so the donut joint for centre pipe will be in a slightly different position.
2002 SG XT Auto
Mine looks the same as the assembly in the advert.
Do you mean the doughnut joint is further forward/backward than mine? I'm gonna get a center pipe built soon anyway.
I just don't know how i'll get it up to Sheff.
Thanks.
Thanks.
The difference was discussed way back and search can't for some reason find it.:confused:
Simon knows the figures........:biggrin:
2002 SG XT Auto
Hmmm. Might leave these then. Apart from the problem of getting them up here, you can't see the state of the steel exhaust under the shrouds. Would be a bargain though.
I'd still like to know if they'd fit though incase i come across another set.
Thanks.
2002 SG XT Auto
Thanks.
From what I can gather, having had another look
MY98 on SF N/A "Converter Assembly - Front" is now 44139AE071
MY01-02 Impreza N/A "Converter Assembly - Front" is 44139AE071
So yes it would fit.
If it was split at the joint separating the manifold from the converter pipe it would be easier to ship.
What about these then?
subaru wrx de-cat exhaust pipe on eBay (end time 28-Mar-10 20:29:59 BST)
http://cgi.ebay.co.uk/SUBARU-IMPREZA...item20ac01d0c0
http://cgi.ebay.co.uk/Subaru-Impreza...item19b8095d8a
I'm gonna get a center pipe made so position of doughnut flange isn't really important.
These are all second cat pipes, where as yours is all in one.
If you are just after the second cat they may be OK but you would also have to cut and fit a flange to your existing pipe and plug the sensor hole.
Hope that's helpful.
1 - 10 of 10 Posts
