New Forester owner here, just purchased a 2021 Forester Premium. Need to add a winter wheel/tire.
Stock is:
17x7 48 offset OEM wheel
225/60R17 Briggstone ECOPIA 422 Plus (totally crap tire to be replace next summer)
Typically I would go minus 1, but some tire sites seem to think a 16” wheel is a no-go. I’m not sure why (maybe brake clearance?). So I started looking for 17” tires. I’m pretty partial to the Blizzaks. Had good luck on several vehicles. Unfortunately they don’t come in the stock size. I really don’t want to change circumference much at all. So then I start looking for slightly narrower, but with bigger ratio. Here is where I ended up.
Proposed winters:
17x7.5 40 offset Motegi MR139
215/65R17 Blizzak W90
Weight of this combo about the same as OEM
All the calculators seem to indicate it works, but with 7mm scrub.
Questions:
- Anyone running a 16x7” wheel on a 2021 successfully (so I could go back to the minus 1 plan)? What offset?
If not,
- Does the small scrub difference on my proposed setup really matter on a Forester (handling)?
- Am I being stupid to give up the 10mm on tire width? (Some would say narrower is better in the snow anyway)
- What would be your go to setup on a 2021?
Thanks in advance for any help!
Sent from my iPad using Tapatalk
