1 - 10 of 10 Posts
2007 FSTI and X 6 MT
Yes it will fit
You can reuse the oem driver side bracket. The pass side will require to be extended. Its as simple as bolting it on and taking a piece of metal and making the new bracket. I modded both opf my brackets so my tmic sits angled more.
2004 fxt A/T
If you are considering it without a vfxx turbo it won't fit. The wastegate sits higher on the MHI turbos compared to the IHI's and the TMIC will hit it. Otherwise read above.
2004 fxt A/T
so...based on this figure, i could just buy the passenger side bracket?
#2 "Support Right"
Nope it is the same as yours. They actually changed the driver's bracket on the 08+ STI's but if you use it the outlet of the intercooler does not line up with the throttle body. I wouldn't worry about it too much either do what tuned said or go without the passenger mount (that's what I am doing) you will have plenty of support from the driver's bracket, throttle body, and turbo coupling.
1 - 10 of 10 Posts
