MikeD,
In theory you are right and initially I was worried about this. However on a couple of properties where I have used these units I checked next door and, even without encryption enabled, I couldn't get a connection. I think the meter possibly blocks the signal.
The units themselves are 4.5w and use 0.06Amp so I don't see even three units using very much power.
Brian,
In reply to your PM you need a NET-PL-85PE_MK2 which you connect (using the cable provided) to a spare network port on the back of your Homehub.
If the PC and the laptop are in the same room you need a NET-PL-85PEW_MK2 as this unit has a network port as well as the wireless connection. Again use the lead provided from the unit to the PC. If the PC is in another room you need another NET-PL-85PE_MK2
The only problem I have had with these units is power transformer units for other equipment, if plugged in beside the Homeplug, can stop it working. Most transformers don't cause a problem but if they do then move them to a socket further away. I normal try to plug the unit direct into a double socket and then use a 4way extension for all the other gubins.
Hope this helps,
Max.
