1 - 20 of 20 Posts
As advertised the hood on my 03 XS is made of aluminum (Aluminium for those down under and across the Pond) Does anybody know why it is aluminum other than the obvious reason, reduced weght? There must be additional reasons, for them to go to all that trouble?
Shure is nice, it is easy to lift and hold up.
Will it dent easier? Anybody had any experience there? 8)
I have been wondering the same thing, I guess it also helps to disperse heat from the Engine bay. Would be nice if the whole car was Aluminium but there are limits to what we are prepared to pay.
I thought all newer subarus are made out of aluminum throughout all of the exterior panels
D
Guest
I think tha reason is because their paint sucks so bad they figure all those rock chips that we get won't be able to rust with the aluminum up front, just a thought... Any thoughts on this.
I was also wondering if the newer WRX's have aluminum trunk lids anyone know about this???
The convert formely known as Lexusfreak
2003 XS
Reduction in weight = lower center of gravity = better handling + better fuel economy without any sacrifice in safety to name a few. :)
On that note, has anyone else noticed a slow deformation in the aluminum hood over time? When viewed from the front, the panel gap between the hood and the grille/headlight is getting noticeably larger on the passenger side of Subed than the drivers side. It's almost like the air entering the area where the stock intake would be (behind the pass. side headlight) pushes the hood up over time. At the same time the hood seems to sag a little along the alignment with the drivers side fender. Am I driving too fast? :confused:
2004 FXT '05 6mt r180 Carbonetics 1.5w lsd
I agree.
On one note, the hood of my '95 legacy weighs a ton compared to the F-XT.
On another note, I totalled my first F-XT and now on my second. I noticed no safety issues re the hood with the impact suffered in the first F-XT. It deformed normally and w/o damage that would endanger the driver.
2004 FXT MT Cobb Stage 2
That's easily fixed. There are rubber bumpers above the headlights on the radiator support. Screw them in or out by hand to adjust the hood gap on each side.
V
Guest
Will it dent easier = Yes!
I threw my dogs bone into the backyard, clipped a tree and it fell onto my bonnet...it now has a couple of small dents to remind be what a bad thrower I am.
I had another accident in the first year of owning my MY04XT where the wind blew some building site materials onto my car and the bonnet suffered real bad. The panel beater said there was no way it could be repaired and the whole bonnet needed replacement.
Panel beating Aluminium, from what I understand, is not that easy and it deforms differently.
The fact that the Subaru dealer (and mechanics) make it clear that to close the bonnet it should be dropped and not pressed down just goes to show how easily it can be dented.
Vas
2010 FXT Limited 4EAT Sport Shift
Pleiad-
I have noticed "temporary" deformation of the hood when sudden wind gusts or semi's pass...it's like the hood enclosure expands like a baloon.
Re your hood deformation, it's probably the engine rotation torqueing the body!
-Quick
Harbor Fright
2005 XT
Quicksilver said:
Pleiad-
-Quick
Passed by a Semi!???
Good one!...:razz:
German tech
MY16 Audi S3 Sedan DSG 6 speed
Vas
You should use that technique with all hoods/bonnets. Saves getting hand prints on the paint too. Also ensures the bonnet is truly closed.
As for denting easier, haven't noticed any problems. Guess it depends what alloys they have used with the Al if any
I have notice that the hood will try and lift up when driving at highway speeds into a wind. I have the hood deflector on the front so I thought it was that... it's pretty unnerving to see the front edge of the hood lift.
BTW, I was driving into a 40 mph headwind when I really noticed it. It also happens (as previously noted) on gusty days. On most normal highway driving it's ok.
Im surprised/jealous, I dont think any version of SF's got aluminum hoods, one things for sure, the steel body panels are thin and delicate enough, my steel hood might be the only panel that doesnt have small mysterious dents on it.
my wrx bonnet/hood used to lift about 130mph :D . The larger scoop is a contributary factor ........
B
Guest
for safety?
Actually, a rep from SOA said they use aluminum on the foresters so that it will bend upon frontal impact rather than sheer through the windshield. Dunno if I believe it. Just what they said.
1 - 20 of 20 Posts
