Hi Josey. Foresters are known to pump out a lot of condensation when they are cold and if yours has been sitting a while perhaps this is exaggerated. If your nerves can endure it, try getting the engine up to operating temperature and check again, mine (99 turbo 5MT) looks like a steam engine sometimes. Good advice from Shalootm to check content of vapour with your fingers. Oil+water will leave a slippery residue but steam will dry off like any water with a bit of rubbing and leave nothing behind. It is also possible that if your Foz has been laid up a year then a bit of oil could have leaked into the cylinders but burning oil always presents itself as blue smoke. Before drawing a conclusion, might a drive clear the engine out and give you a better overview? After that, as suggested above, if there is water in the oil (white deposits) or bubbles in the coolant, then at least you have a starting point. Good luck.
