2004 Forester 2.5 XT 5MT
SF5, EJ257/EJ205 hybrid, MT (swapped from AT)
My radiator just began leaking. It is still the stock NA SF radiator. I'd like to get the correct radiator but since we were never offered turbo SF in Canada, which rad would be a correct drop-in fit? GD WRX? Will the coolant and reservoir hoses fit?
Thanks
98 Forester S 5 Speed
I used the Gimmick motorsports "Swap" Radiator for my 04 wrx swap into my 98 Fozzy. The stock fans bolted up without issue as well as the stock coolant overflow tank. Trickiest part was finding a lower hose to work because the outlet was mounted little higher than stock. A few trips to the parts store and a little experimenting sorted it out in the end.
Gimmick Motorsports Swap Radiator Pre-02 Impreza Import Image Racing
