1 - 13 of 13 Posts
2011 Forester XT Touring Auto
where is drain tube on 2011 Forester XT?
I am trying to try out foaming AC evaporator cleaner.
2007 FXT Limited 5MT
Should be right on the firewall behind the turbo, maybe a little lower
picture would be helpful if anyone can provide it.
I wouldn't even know where turbo is. hehe
open the hood, look at the left side of the intercooler, slightly down and to the left of the intercooler is the downpipe (exhaust pipe with heat shields on it) directly behind the downpipe is the firewall, look at the firewall and follow it downwards till you see a medium sized black hose coming out of the firewall, maybe 6 inches long
is tube metal? I see one possible candidate but it goes down near front left tire and I can' t get good look on it without lifting the car.
2004 Forester XTi 4EAT
It should be a rubber hose protruding from the fire wall at an angle.
2004 Forester 4EAT
I'm not 100% sure on the SH models, but I'm almost positive it will be a rubber hose about 3/4" in diameter pointing down. It will just have an open end. The hose will "disappear" into the firewall just about where Conner said it was. It's below the big wiring harness thing too. It's down there quite a ways. I would bet it would be easier to get to it from below.
1999 Forester 5MT
Passenger side of the engine bay, coming out of the firewall near the exhaust, down low.
Edit: Here, except it'll be pointing down.
Discussion Starter · #9 ·
Is drain tube clear tube? So firewall is on left side of picture in this case?
2004 Forester 4EAT
The drain tube is the black tube in that pic. The clear tube is something he has shoved in it. He also has it pulled up. It would normally be facing down.
Discussion Starter · #11 ·
ok I think I found it. It was on passenger side as indicated and way down there! Thank you for your help.
I will make sure I see some water dripping before I apply foaming cleaner.
Discussion Starter · #12 · (Edited)
well, I drove for 20 minutes in 60 degree weather (with AC on) and could not get water to drip through the tube.
It looks like it is in right place and end of tube is clean (no oil, grease). Tube is black and flexible. Is there any chance this can be anything other than evaporator drain tube?
I don't want to make a mistake of putting foaming cleaner into something else.
1 - 13 of 13 Posts
