The Modfather
2016 BRZ Limited - Manual 6 Speed Manual
I was looking around for something on my hard drive and found this again. I did not make the attachment, just passing it on. Thought it might be of interest to someone. The spreadsheet has all sorts of cool calculations. I'm not sure if the formatting will hold up but here is a partial cut and paste:
Wheel / Tire Weights and Rotational Inertia
Car and Wheel Dimensions: wheel 1 wheel 2 Derived dimensions wheel 1 wheel 2
Wheel size (inches) 16 17 Wheel Radius (feet) 0.67 0.71
Tire width (mm) 215 225 Tire sidewall height (feet) 0.42 0.33
aspect ratio 60 45 Tire radius (feet) 1.090 1.041 (~same)
wheel weight (lbs) 22.0 19.0 wheel mass (slugs) 0.68 0.59
tire weight (lbs) 21.0 25.5 tire mass (slugs) 0.65 0.79
Total wheel weight 43.0 44.5 total mass (slugs) 1.34 1.38
Car 0-60mph time 5.3 Linear Acceleration in ft/sec^2 16.60
Wheel rotat'l accel'n radians/sec^2 15.23
Note: Units for inertia are slug feet^2
Formulas Implied Radius of Gyration
I1=Rotational Inertia 1, single uniform density disk 0.793 0.748 I=1/2 (MR^2) Rgy = .71Rt
I2=Rotational Inertia 2, Tire Disc + Wheel Disc 0.684 0.775 I=Iw+It
wheel alone (solid disc) 0.152 0.148 Iw=1/2(MR^2) Rgy = .71Rw
tire alone (hollow disc) 0.532 0.627 It=1/2M (Ra^2+Rb^2) Rgy = Rw + .54(Rt-Rw) approx
I3=Rotational Inertia 3, Two Discs, Edge Weighted 0.861 0.949 I=Iw+It
wheel alone 0.202 0.197 Iw=2/3(MR^2) Rgy = .82Rw
tire alone 0.659 0.751 It=M (Rg^2) Rgy = Rw + .8(Rt-Rw)
Rotational Torque G=IW Torque Loss Per Wheel, Ft-lbs Tq difference Per Wheel Torque difference * 4 wheels Torque Diff, rot'l+linear Total Added Chassis Weight Equiv, W2 vs W1
Uniform density disk, Tire + Wheel 12.1 11.4 0.7 2.7 -0.6 -1.1 lbs
Tire Disc + Wheel Disc 10.4 11.8 -1.4 -5.6 -8.9 -15.9 lbs
Tire Disc+ Wheel Disc, Edge Weighted 13.1 14.5 -1.3 -5.3 -8.7 -15.5 lbs
Torque devoted to linear acceleration 24.2 25.0 -0.8 -3.4 -6.0 lbs ( linear only )
LIMITATIONS:
All rotational inertia models are approximations, but model 3 may be the most accurate.
The two wheel / tire combos are assumed to have the same total radius (wheel1) when calculating the acceleration rates and torques.
2009 Forester 2.5x 4EAT
@Peaty can you try posting again, but use the # code feature on the advanced reply button? I think that should hold formatting, but not sure if it will work with Tabs.
The Modfather
I think that looks a little better, but opening the zip gives a bunch of info and has a few tabs.
