Answer: Not long enough.
Do a search. It's a common problem. My 2003 XS has 75k and it has a bad wheel bearing. Dealer quoted me $700 to fix. Local Subaru shop quoted me $400. Not really a DIY project as it requires expensive special tools. Thanks Subaru!
hub shark sets aren't that expensive if you don't buy the professional version. if you already have 1/2 drive sockets and other typical hand tools, patience, and elbow grease you can save a lot of dough on a Saturday. Be sure you buy all the required oil seals and dust seals too, in addition to the bearings and take careful note the correct way to assemble.
Note I haven't actually used this particular set on a Subaru, but it seems better than my homemade set!
- Harbor Freight Tools - Quality Tools at the Lowest Prices
The Hassle-Free Way to Change the Front Wheel Bearing!
Change front wheel bearings without the hassle of removing steering knuckle or strut assembly.
* Eliminates need for front end alignment after service work is done
* For use with both domestic and import front wheel drive cars and light trucks
* Corrosion resistant black oxide finish
* Packed in a blow mold case for easy transport and storage
