We just say "alignment" here, you get a front alignment for $50 or 4 wheel for $80-100. What is a full geometry setup ?
That is correct, it doesn't describe setting up camber but that is even easier. Each strut is attacehd by 2 bolts at the base near the axel. In the front the top bolt is the camber bolt, the rears don't have camber bolts from the factory. ( I use H&R camber bolts in the rear.) Anyway, you loosen the nuts on both bolts (otherwise the camber bolt won't turn) and adjust the camber bolt to give the desired camber. Tighten the bottom nut then hold the camber bolt with a wrench (if it moves you change camber and have to start over) and tighten the top nut. Presto !
Truth be told, there's not a whole lot of adjustability with the camber bolts so I always max them out negative. That is to say if you were looking dead on from the front you'd see the top of the disc brake lean towards the car. That's negative camber. There's maybe 1-1.5 degrees of adjustiblity with camber bolts. Thats why I run camber plates. I can dial in another 3 degrees with them.
Again, adusting camber is a cinch and is part of the 1 hr job alignment shops do here in town. The sequence is : install suspension, adjust camber, thrust angle and then toe.
Full geometry setup is camber, toe, thrust and, if adjustable, castor.
As you say, adjusting the camber is quite easy but to set it accurately, you need a gauge really - you could do it with a spirit level or a plumbline but it's a lot easier with a proper gauge. Also, just maxing the bolts out doesn't necessarily result in equal camber on both sides.
The guys that do my geometry use a system that mounts to each wheel and measures all of the above and allows them to adjust very accurately. Once it's all done, I get a nice printout of the before and after measurements to take home with me :biggrin:
To be honest, for the £60 they charge, it's a lot let stress to have them do it - plus I can leave the car there all day and save myself the cost of parking which offsets the £60 a bit, they make a mean cup of tea too! :biggrin:
