I doubt changing the wheels and keeping the same tires would change the road noise at all.
Yes, the Geolanders. Didn't notice the road noise so much with the stock wheels and tires. But when I changed to Michelins and after market wheels at the same time, that is when the road noise became more noticeable. Took back the Michelins.the tires are going to determine the amount of road noise not the wheels. Are you running the stock tires?
Yes the Michelins were your problem for sure. Michelins are known to last a long time. But it is only because it is an extremely hard tire. All season Michelins sacrifice all performance areas for longer life. That is fine but it is not the best option as you found out.Yes, the Geolanders. Didn't notice the road noise so much with the stock wheels and tires. But when I changed to Michelins and after market wheels at the same time, that is when the road noise became more noticeable. Took back the Michelins.
