1 - 8 of 8 Posts
2004 Forester XT 5spd
My FXT is almost out of the shop and when it's done it will be full stage 2 with a VF48.
I need gauges.....badly. I've ordered the center console 2 din expansion and plan to mount three gauges in it. I have already ordered a ProSport electronic boost gauge but I don't know what's important to monitor after that?
Oil temp? Oil pressure? A/F ratio? Badass status?
I've searched all over and the only definite answer I have gotten is "boost".
What's important after boost? I'm leaning towards oil pressure and A/F ratio.
Thanks all!
none none
Wideband and EGT if you're tuning. Otherwise boost...
Maybe oil pressure, especially with the weakness of the stock oil pickup tube.
Lately I've been thinking about doing some sort of fuel pressure gauge, but thats really only needed under the hood when diagnosing.
2006 Forester XT
Bling!
Just installed the ProSport Boost gauge, and I'm 'less than impressed'.
You have to pick the illumination color (white or orange) before you install, the wires are very short, and the needle is barely visible, even when brightly lit.
If you don't want to get the expensive DEFIs, look at Glowshift - Black 7 Color 30 PSI Boost / Vacuum Boost Gauge don't let the name put you off, they are good value, very visible and the color can be matched closely to your dash.
and did I mention? really cheap....
S
Bling!
S
Well......****. I guess I'll return the ProSport then. They came recommended by a local guy. I am looking into adding an in-dash computer and come up with my own custom gauge display on that....but it will take some time. :-/
TY for the input.
I'm not doing the tuning myself, I'm having a protuner do that.
How about boost, wideband, and oil pressure.
07 Forester XT
I have a simular setup to yours and run oil/water temp & boost. I want to see temps while I'm running at the track so I don't overheat anything.
2003 Cross Sports
The Prosport electronic boost is OK. I've been running one for over 2 years and it seems to be holding up. I can't highly recommend their other gauges as I've gone through 3 fuel pressure and 2 oil pressure sending units. I'm considering swapping out the lot soon. Possibly with STRI
1 - 8 of 8 Posts
