1 - 10 of 10 Posts
2009 2.5X EJ253 Manual
The 2009 Forester Service Manual module that covers changing the rear differential fluid does not specify what size bit is required for the fill and drain plugs on the diff. I tried a 1/2" ratchet head but its not a snug fit.
Anyone know the metric size for a square bit to fit the plugs?
2019 Crosstrek 2018 XT
1/2" works but the correct size is 13mm.
To get it off you will need to put it up on a ramp to get leverage and use an 18" breaker bar. That *&*&^&*(())*& is on there. I tighten mine up well under the recommended torque.
2003 Cross Sports
The 13mm socket is the way to go. I first tried the 1/2" breaker bar that most people use and nearly rounded off the diff plug. I bought the 13mm socket from Ultimate Tool (a supporting vendor here) and couldn't be happier with it.
2003 Forester Manual
Would anyone know if the drain plug size is smaller than the fill plug size? For some reason, the square on the lower plug on my 2003 Forester looks smaller than the upper.
2009 Forester X AT
I wonder if someone drained it before with a 1/2 inch drive and slightly enlarged the opening?
That said, I've always used the 1/2 drive. If it's really tight, I juice it up with PB Power Blaster, and have even used a floor jack under a heavy cheater bar - just slowly jack the cheater up, and let the weight of the car break the tension.
One other tip - if you're not accustomed to doing this service, it's a Very Good Idea to remove the fill plug before the drain plug. If you drain it and then can't get the fill plug out.... well, you can just imagine what creek you'll be up.
1 - 10 of 10 Posts
