1 - 20 of 106 Posts
admin
What is your ride height? How does it compare to other Foresters?
Post your measurements and I’ll add them to this spreadsheet. I think I will keep it sorted highest to lowest. I’m real interested to see stock measurements too. Especially how the new higher 06's compare to earlier models.
Here is how to measure your wheel arch height.
I’ve added ground height which is taken from ground to the fender. This takes into account tire size.
I took my measurement with an ordinary tape measure. Not the most accurate way to do it but it should be fine for this. I used this site to convert my measurements to metric. Doing this in metric makes comparing and sorting easier.
http://boat.endtas.com/convert.php
2011 Toyota Tacoma DCSB Auto
a good thing to note also is psi of tires, and mileage on chassis/suspension
admin
Good ideas. :icon_biggrin:
They have been added.
So where all do you need measurements from?
I assume ground to front fender top, ground to rear fender top and ground to ????????
Mr. November 2008
2015 BMW 335d xDrive GT Auto
Forester STi (06) on AST Sportline II height-adjustable coilovers. 2000 miles.
Ground to bodywork F 690 mm R 700 mm
Centre of wheel to bodywork F 385 R 395
Tyres: 235/40-18, F 35 PSI R 33 PSI
Measured with tape measure after half a bottle of wine :biggrin:
At the moment the suspension is set fairly high, a future revision to the ASTs is likely to drop it by about 20mm.
admin
The first measurement is front fender to wheel center, rear fender to wheel center, then ground to front and rear fenders.:icon_biggrin:
06 X Auto
2006 Auto Auto
2006 X (US)
Ground to fender F 749 mm R 753 mm
Center of wheel to fender F 440 mm R 441 mm
Tires: 215/60-16, F 36 R 35 pressure
10,200 miles, tires have 2,200 miles on them
1/4 tank of gas left, stock suspension. Full size spare which weighs more than the OEM donut.
2017 Forester XT touring CVT
2004 F-XT
approximately 15K miles on current suspension setup.
Half tank of gas.
225/45/18 tires @ 26psi front & 27psi rear
stock struts
WRX springs front & Forester specificTein H-Tech springs rear
wheel arch front=14.875"(377.825mm)
wheel arch rear=14.750"(374.65mm)
ground/arch front=26.875"(682.625mm)
ground/arch rear=26.75"(679.45mm)
2012 camry se 6AT
Great idea SuperRu. This thread needs to be a sticky!
MY03 F-X
02-03 WRX Sedan KYB GR2 struts
02-03 Swift WRX Wagon springs
~8K miles on current setup
3/4 tank of gas
225/45/17 tires @ 34/33 psi F/R
Front fender to wheel center = 355 mm
Rear fender to wheel center = 660 mm
Front fender to ground = 343 mm
Rear fender to ground = 654 mm
admin
Discussion Starter · #10 ·
Thanks, :icon_biggrin:
I didn't think I would be the lowest for too long.
Let's hear from some of you off-road folks.
Harbor Fright
2005 XT
Not sure if L/R measurements will help, but mine are definitely not symmetrical:
2005 XT, full tank.
~31K Mi., ~5K on tires.
215/50-17, 38 PSI F&R.
Springs (Same as Yelnatsj): WRX F, H-Tech R on OEM FXT struts.
Arch Front Left: 376 Arch Front Right: 378
Ground Front L : 688 Ground Front R: 690
Arch Rear Left: 374 Arch Rear right: 380
Ground Rear L : 686 Ground Rear R: 692
Looks like I am suffering from the dreaded left-rear sag (which I've noticed, but not bothered to measure before...)
I think I'll go for a ~5MM spacer in the left rear strut to even things up a bit- can't hurt the corner-balance, either (which I've also noticed when turning left vs. right, but also never bothered to pursue...where's the lazy, yawning smiley when you need it? :icon_idea:)
2004 FXTi
Current ride height (road to fender lip at wheel center):
Front: 654mm
Rear: 673mm
Current ride height (hub center to fender lip):
Front: 356mm
Rear: 375mm
Sorry, don't have "before" measurements.
Keep in mind, I'm running tires that are Kuhmo MX 225/45-17's.
PSI is 36 all around.
5K miles on suspension
Suspension is v8 spec C struts and 2005 Prodrive STI springs, front PDE camber plates.
Regards,
Justin Wade
2004 FXTi
Currently mine is 445 wheel arch height and 780 to ground.
Next week (after adding some custom Kings Springs) mine will/should be 465 front / 470 rear; so 800 front / 805 rear approx.
15" wheels / BFG A/T 21575R15 @ 38 psi
KYB Excel-G / GR2 struts; Kings Springs (30mm lift reset -20mm front & -15mm rear); SubaXtreme 40mm lift kit.
MY'03 XS / 3/4 tank / 43K (hard) miles!
I'll update again when the spring job is done.
Front: 774/455
Rear: 786/462
2002 S Premium, AT
1/2 tank gas
215/65-16 Pirelli Scorpion ST, 36psi
40 mm lift kit
Brand spanking new KYB GR2 struts, 70k miles on springs
Any chance you can put the stock dimensions at the top of your chart, in chronological order?
admin
Discussion Starter · #15 ·
Is that better? Suggestions are appreciated. :icon_biggrin:
That is perfect! And I'm at the top of the list! :Banane08: At least until Kevin gets his springs sorted out.
05's XT/GT
05 XT - 1/2 tank, <2000k on KYB AGX/WRX wagon springs, struts are set at 1F/2R if it matters.
wheel to fender F 375 / R 375
ground to fender F 695 / R 695
225/50/17 - 37/35psi
I was a little suprised to see the front and rear exactly the same, but I double checked it. It is what it is.
The Sub kit guy
2005 Forester X & XT VF39
2005 X - 15,000 miles, stock suspension
225/55/17 31psi F/R
1/2 tank gas
wheel to fender F 431/ R 428
Ground to Fenter F 749/ R 749
Jobs done - it's actually 10mm higher in the front and 10mm lower in the rear than I expected :icon_confused: I'm wondering if it's possible to get the front & rear springs the wrong way round?
Front Arch now 475mm / to ground 810 mm
Rear Arch now 460mm / to ground 790 mm
1 - 20 of 106 Posts
