1 - 11 of 11 Posts
F
Guest
sirwilliam said:
Too low for me, yes...for you, not sure.
You just want to make sure your tires will not be rubbing...what size tire are you running right now w/ your 17s?
215/50's
I am just looking for a fairly cheap way to upgrade my forester suspension as the power/handeling ration is getting bad, and it will only get worse whe i get my vf39
2008 SG Model D
FXT said:
215/50's
If you are going to go that low I would recommend something closer to what the WRX/STIs are running like 225/45/17 which will give you a little bit stiffer sidewall w/ a slightly lower profile for better handling...It shouldn't but not positive if your 215/50 will rub or not w/ that setup you are looking at.
215/50 = 107.5 height
225/45 = 101.25 height
2012 camry se 6AT
I think that will be a killer street setup. Less strut travel will really help reduce the "boat" feeling. The progress springs drop the WRX 1.8"/1.5" Front/Rear which most likely drop the Forester approximately 4" all around. RoundtheBend has his XT dropped 4" all around and it looks really good. Expect a significant decrease in ride quality and functionality with this setup. But if increase handling is your goal, this is gold.
I prefer having the top of tire to wheel well distance at least as great as the distance from the tire to wheel well measured horizontally.
2005 Forester XT
Ive never really understood why people lower their foresters, is there really that significant of an improvement to justify doing it? Maybe it's just me, but I've always thought lowered foresters look kinda akward.
2008 SG Model D
Foresters are hindered by a high center of gravity like all SUV/Wagons. By lowering the car you are lowering the center of gravity for better handling on road and in the twisties.
Myself, I like the lowered look. But it is whatever floats your boat or makes you happy. Of course by lowering the car you are inhibiting the offroad capabilities...but if you never go offroad then you don't really need the ground clearance unless you live somewhere like the artic circle that gets a lot of snow.;)
F
Guest
Discussion Starter #9
Well with a vf39 the stock supension is completely dangerous. You need to have a balanced car which includes power, breaking, and handeling. The suspension was even a bit soft with stock power, but now that I am stage 2 and about to be stage 3, its getting dangerous.
2008 SG Model D
Haha. It's not completely dangerous, just not made for the power increase. I have been on stock setup w/ the STi swap for 10K now...but you definitely want to improve the suspension and braking.;)
2006 XT
From reading Subaru Motorsports threads all over, there is a point (when the control arm is level to the ground) when beyond that handling gets worse. The 4" drop FXT should be checked for this???
I agree there needs to be balance in HP/Brakes/Suspension Mods, but driver skill is often overlooked. I recommend a Spring Evolution class, it's a meager $300, but worth ten times that in mods.
1 - 11 of 11 Posts
