2164427 Views 18556 Replies 3027 Participants Last post by  2WheelsGood
1321 - 1340 of 18557 Posts
Tomorrow: (pending)
Pick up STI Hood scoop painted DGM
Install Subtle trunk brace
Install Moboost rear strut bar
Thursday: (pending)
Install Subtle splitter
Install STI Hood scoop
Install Brembos
bleed brakes
Install CRV wheels with snow tires
road test!?
Thusday: (actual)
Installed Brembos
Friday: (hopefully)
Sunday: (hopefully)
Install STI Hood Scoop
Install Subtle Splitter
Refill Power Steering (oops used PS fluid not ATF Dexron)
Check Tranny/diff levels (again)
Bleed brakes
Bench bleed master cylinder
Install CRV Wheels with snow tires
Install Moboost rear bar
Install rear seats
Monday: (hopefully)
get an alignment
Tuesday:
mover comes and takes her away to MI!
Built my Bull Bar, just need to paint it and install it! Pictures to come.
I beat the ballz off it. Ran it as hard as possible through the Pocono Mtns. Good Times!
Sometimes ya gotta get the lead out :biggrin:
Ifeelya.
Yelled at it! After giving up trying to install this 16g for the day.
4,000mi oil change / NAPA Premium 5W-30 / Lucas Oil Stabilizer ...
Drove it into a wall... Oops.
You did WHAT???
Gave mine a bath and "sensual massage" followed by some pics....
:lol:
Installed some HID fog lamps. Color is a bit off I think it may be my camera.
Used it to take me and my new (to me) Specialized Mountain Bike to the desert trails way off the beaten path.
Used it to get the pulley kit I ordered. That said I don't get why it's called a kit. The kit is one pulley. That's it. Made of aluminum ofc.
Bulbs or complete lightning units?
Reinstalled the intake manifold.
What a PITA trying to get the samco turbo inlet onto the turbo, had to make a mini "shoe horn" as the edge of the hose kept getting caught on the turbo instead of slipping over it.
Possibly the most satisfying moment when after 2 hours of wiggling it finally popped on.
Dont tell me this, as I plan to swap my gimmick out this winter for the samco I have....:chair:
Supposedly the samco fits better than the gimmick. The edge of the hose on the underside just kept getting caught on the 16g's compressor inlet. I ended up bending some wire up to make an L that I could just stick between the hose and turbo and slide around the compressor inlet to pop it on. That combined with lots of wiggling finally got it in place. If you have your tgv's deleted it should be a piece of cake though as I had no wiggle room on the turbo side of the IM.
Also got the phenolic spacers on at the same time, ended up RTVing the upper gasket to the spacer as it kept moving out of place whenever I put the intake manifold in. With it RTVed it was much easier (could slide the intake manifold around ontop of it to get everything positioned correctly)
Tgv's are still in place here. Do you think the spacers helped? Im on the fence on pulling the Tgv's and adding spacers when I pull the manifold.
