1 - 10 of 10 Posts
99 stb
its on top of the rocker cover (one on the other side of the engine too)
looks like sum sort of breather pipe but nt sure,as you can see it needs a new gasket on it.....................but what is it?:shrug:
i cant order anything till i know:icon_frown:
MY11 WRX STi Sedan 6MT
With a 97 S/Tb, I expect yours will be the earlier version cam covers for the EJ20G engine as per here................
http://opposedforces.com/parts/impreza/en_g10/type_13/engine/rocker_cover/illustration_1/
http://importcarparts.co.uk/parts_info.asp?id=5045&cat=96&sub=97&sec=223&var=54&dc=y&gen=&searchKey=
Unless its an EJ205 engine :icon_biggrin:, then its this shape..........
http://opposedforces.com/parts/impreza/en_g10/type_42/engine/rocker_cover/illustration_1/
Need to clean it up first, the, separator cover may just need nipping up, or a clamp on the breather pipe.
its a 99 stb, ive got another 1 now :biggrin:
which engine should it have?
So you've updated your profile now???
From your photo it "looks" like the EJ20G, but the easiest way to tell would be to remove the air filter casing and check the shape of the oil separator.
The difference is clearly shown in the illustrations. (Just to help the EJ205 is longer and tapered at one end :biggrin:)
1 - 10 of 10 Posts
