1 - 7 of 7 Posts
I've got my timing belt removed and was planning to replace water pump. Manual indicates that driver's side camshaft sprocket must be removed to remove rear cover, presumably for access to the tensioner bracket or water pump. When I looked closely I was not sure the sprocket and rear TB cover need to be removed.
The following post from several years back suggests that removal of camshaft sprocket is not necessary.
http://www.subaruforester.org/vbulletin/f66/timing-belt-pump-change-14416/index6.html
Anyone know for sure?
Thanks
It's a SOHC and yes I read that post (it's linked in my post). I could not tell whether he removed the sprocket to access the water pump. First pic shows water pump removed and sprocket in place so I suspected he did not.
thanks
2001 Forester S
Sorry didn't realize it was a different point on the same topic, I'll blame that on swine flu. The Chilton service manual I have says you need to take off the timing sprocket but the more I jogged my memory I am pretty sure I changed my water pump with the sprocket still on.
BTW if you are a Texas Tech fan are you watching the game, ABC 2:30 CT?
Forester '09 X Limited
I found it very difficult to slide the water pump in place with the cam sprocket in place until I applied a little dish soap to the rubber on sprocket housing (driver side of pump) and water pump side rubber (passenger side). It is a tight fit! It slid fairly easily at that point. It was a pain getting the bolts to align while keeping the gasket in place though.
1 - 7 of 7 Posts
