1 - 20 of 22 Posts
with temperatures between -10° and -20°C around here, I was wondering what are your methods of warming up the engine? Do you try to go at a certain RPM? Do you care? How many of you use electric block heaters? How many use Webasto or similar fuel-consuming heating systems?
I try to go at 2500rpm consistently until the engine has warmed up, I once read that this was good for the engine. Is that so?
2008 XT Sports
Block heater is the way to go. Costs about $30 and maybe $100 to install.
Definitely worth it if you see freezing temperatures for a couple months per year as we do in Canada.
Extensive study was conducted recently by the Canadian Auto Assoc. (CAA) on the topic.
link to the CAA brochure here.
10 XT 4EAT
my method depends on whether i have to scrape or not. If i have to scrape, start car, let idle while scraping, when done get in and drive. If i don't have to scrape, really depends on outside temperature, but i let it idle for around a minute, then start driving.
untill the blue coolant light goes off, as per the manual, i definately don't take it over 4000 rpm, but typically kinda keep it under 3000 until the light goes out.
The fastest way to warm the engine is to actually drive it. The past 'studies' that i remember said to only let the car idle for 30 sec then start driving it.
oh, i also use the block heater once colder then -10C, which is usually most of time.
I start the car and let it idle until warm. I think the key is to warm it up under no load until the car is at operating temps.
No. You need to drive it under low load conditions until it gets warm.
Let it idle a minute or two then drive off. Keep it below say 3000 rpm (your 2500 rpm is fine) until its warm.
2009 Forester 2.5x
A block heater is nice. The engine gets a relatively warm start, which means less wear on the internal parts, and the whole works come up to operating temp more quickly. I plug mine in for about 3 hrs. before starting whenever the temp is near or below freezing. Once started, I pretty much just wait for the fuel injection system to lower the revs on its own, a couple of minutes, and then gently drive off. Even tho the engine may be relatively warm, remember your transmission and differential fluids are still cold, take it easy on them for a few miles ( or kilometers).
Steve
09 2.5X AT
Block heater sounds good, does anybody know if there are 230Volt Block heaters? All I could find were 115 Volt versions, which don't work over here...
2004 2.0 XT MT
Our Forester is the first car we've had since early eighties without a block heater - which is the way to go; if we keep the car I'll have one installed. Without it, we start driving with low load right after start-up.
2001 SOLD!
We get -20°C too. I have a block heater and never used it since I owned the car. I just start it and let it warm up for 5-10mins depending on outside temperature.
The Modfather
I start it and go, but I watch my oil temp (I have a digital gauge) and I go easy until my oil temp gets above 150°F
2009 Forester 2.5x
An oil TEMP guage...what a great thing to have! Can you tell us approx. how long or how far it takes the oil temp to reach 150F from, say, about 32F? I'd love to know the answer to that...
Steve
09 2.5X AT
2009 Forester 2.5x
Fujisan has done all of us "blockheads" a real favor by providing this link. I just finished reading the brochure and it is one of the most comprehensive reports on the usefulness of a block heater I've ever read. Thanks, Fujisan!
Steve
09 2.5X AT
p.s. the link is a bit awkward to use for the computer-impaired (like me), but stick with it, you'll figure it out and it is great reading. I've already printed my copy out.
Yea..oil temp is the way to go and as I recall it lags water temp. But likely by the time your water temp is at normal operating the oil is good to go.
The Modfather
I'm reading the oil temp from the galley plug at the back of the motor (by the turbo) I found it to be a good indication of oil temp. Better than say the one Subaru uses with its oil temp gauge which is in the oil drain plug. My digital one does not start reading till 110°F and it starts to register in about 2 miles from driving and it gets over 150 maybe after a total of maybe 5-6 miles. I'm just taking a swag I'll try to pay more attention.
1 - 20 of 22 Posts
