1 - 10 of 10 Posts
04 forester xt 5mt
I know about the fitment thread which is stickied. I looked through it but couldn't find anyone running something like this so.. here it goes
Ive been looking at wheels and tire setups for a while here anticipating springtime, my birthday and a new job.
I am on Forester specific Swift sport springs on kyb-gr2 struts.
I do not want to change my suspension setup because occasionally I drive on somewhat bumpy roads and need the clearance, and comfort of my current setup. I want meaty sidewalls to protect my wheels.
Here is what I want to run.
either
18x8.5 +44 rota grids with a 255/45/18 tire
or
18x9.5 +38 rota grids with a 265/45/18
Anyone know if this will fit?
Help much appreciated
2001 Forester
I'm pretty sure 8.5 with 255s will fit. I'm not sure about 9.5 with 265...
04 forester xt 5mt
ive decided to go with the 8.5 setup. anyone else have any idea if this will rub? im ok with using some spacers if i have to.
2013 Forester XT
On my 07, i had 18x8 with a 245/45/18 and the rears needed to be slightly rolled and the plastic trim removed. offset was +45
2006 Forester XT Premium 5MT
Did they end up rubbing??
I'm about to buy some 18x8.5 et48 and hoping to fit a 245/40/18 without rubbing. Car will be on track extensively now that I just sold my e36 m3.
I've searched a lot and found lots of "theoretical advice" but really want someone to say to me, yes - it fits!
2006 FXT 5 speed
I just put 18x8.5 +35 w/ 245/45r 18...i had to do a slight roll on the rear and that's all. you will have a shorter tire and be 13mm inward from me so yes it will be an easy fit inside the fender. I would worry more about your clearance from tire to strut, because off the top of my head i believe you will have 26mm less room than stock.
1 - 10 of 10 Posts
