1 - 7 of 7 Posts
1999 Forester
I have a 1998 Forester.
Just noticed a vibration/grumbling noise when I turn right at slow speeds, such as when I turn into a parking spot.
Any thoughts as to what is wrong/what needs replacement?
Thanks!
1999 Forester
The vibration starts initially when I turn sharply right, again like how you pull into a parking spot, but the vibration goes away the farther I pull to the right.
Still think it's that left wheel bearing? If so, is it an immediate fix or can I go for awhile with it?
Thanks!
2005 Forester
I had a similar noise(slight chattering & vibration) when doing tight radius turns at low speeds. I just did my 30,000 maintenance and changed the front & rear gear oil and ATF and the noise is gone. Your issue could be a wheel bearing but if you haven't changed the gear oil lately, maybe you should look into that first.
1 - 7 of 7 Posts
